BF 533 SPORT with external clock
Question asked by leni on Feb 16, 2016
Latest reply on Apr 6, 2016 by Jithul_Janardhanan
I'm trying to transmit via SPORT interface. I am using the EZKIT LITE Evaluation Board of the DSP BF-533.
It works fine as long as I am using internal clock, but as I want to use external clock in the end, I am trying to change this.
But with external clock the data is not transmitted. The buffers are filled but not send.
Is there anything wrong with my parameters?
This is a minimum example of my code. I connected a pulse generator as clock signal (at different frequencies from 29.7MHz to 59.4Mhz as I was not sure about the maximum possible frequency) with a 50% duty cycle.
#include "adi_initialize.h"
#include <drivers/sport/adi_sport.h>
#include <stdio.h>
#include <string.h>
#include <errno.h>
#include "sysreg.h"
#include <assert.h>
#include <cdefBF533.h> // BF533 Register Pointer Definitions
#define SIZE_OF_TX_BUFFER 1024
/* flag indicating if SPORT processing is complete */
bool bBufferComplete = false;
int dataReady = 0;
/* SPORT driver memory */
uint8_t DeviceMemory[ADI_SPORT_DMA_MEMORY_SIZE];
/* Tx buffers-0 */
uint8_t nBufferTx0[SIZE_OF_TX_BUFFER];
/* Tx buffers-1 */
uint8_t nBufferTx1[SIZE_OF_TX_BUFFER];
void fillBuffer(uint8_t * buffer){
    buffer = malloc(SIZE_OF_TX_BUFFER * sizeof(uint8_t));
    for(int i = 0; i<SIZE_OF_TX_BUFFER; i++){
        buffer[i]=i;
int main(void)
     adi_initComponents();
    sysreg_write(reg_SYSCFG, 0x32);
    csync();
    ssync();
    /* SPORT driver handle */
    ADI_SPORT_HANDLE hDevice;
    /* driver API result code */
    ADI_SPORT_RESULT  eResult;
    void *pProcessedBuffer;
    /* open the SPORT driver */
    eResult = adi_sport_Open(1,ADI_SPORT_DIR_TX, ADI_SPORT_SERIAL_MODE, DeviceMemory,ADI_SPORT_DMA_MEMORY_SIZE,&hDevice);
    // Use the driver API's to configure SPORT
    eResult = adi_sport_ConfigData(hDevice,ADI_SPORT_DTYPE_ZERO_FILL,false,15);
    eResult = adi_sport_ConfigClock(hDevice,1u,false,true);
    eResult = adi_sport_ConfigFrameSync(hDevice,15u,true,true,false,false,true);
    /* Enable the DMA mode */
    eResult =  adi_sport_EnableDMAMode(hDevice,true);
    /* submit the first  buffers */
    eResult = adi_sport_SubmitBuffer(hDevice,nBufferTx0,SIZE_OF_TX_BUFFER);
    /* submit the second buffer  */
    eResult = adi_sport_SubmitBuffer(hDevice,nBufferTx1,SIZE_OF_TX_BUFFER);
    /* Enable the device */
    eResult = adi_sport_Enable(hDevice,true);
    while(dataReady < 10)
          eResult = adi_sport_IsBufferAvailable(hDevice,&bBufferComplete);
        if(bBufferComplete == true){
             eResult = adi_sport_GetBuffer(hDevice,&pProcessedBuffer);
             fillBuffer((uint8_t*)pProcessedBuffer);
             eResult = adi_sport_SubmitBuffer(hDevice,pProcessedBuffer,SIZE_OF_TX_BUFFER);
             dataReady++;
    while(*pSPORT1_STAT & TXF){
        //wait till last bit is send
        printf("wait...\n");
    /* Disable the device */
    eResult = adi_sport_Enable(hDevice,false);
    /* close the SPORT driver */
    eResult = adi_sport_Close(hDevice);
    return 0;
What happens is that I get stuck in a SportStatusHandler function in an endless loop as the buffers are never send.
Thanks for your help!
