(ADV7390)Is there any possibility to change the sync depth with CVBS output.
Question asked by donadona999s on Feb 8, 2016
Latest reply on Apr 21, 2016 by donadona999s
Hi !
Is there any possibility to change the sync depth with CVBS output with not changing the output gain?
Our customer are using ADV7390 as DIGITAL to CVBS.
And they said the output signal level is something wrong.
They input the color bar input signal by digital but the 100% white has only 704mV( I think 1V is correct),
and sync depth has only 212mV(I think 286mV is correct).
Their script is this.
0x17 0x02
0x00 0x10
0x01 0x00
0x80 0x10
0x82 0xC3
0x8C 0x1F
0x8D 0x7C
0x8E 0xF0
0x8F 0x21
0xE0 0xFE
0xE1 0x45
0xE2 0x85
0xE3 0x54
0xE4 0xEB
0xE5 0xB6
0xE6 0x91
0xE7 0xF8
0xE8 0x07
0xE9 0x00
0xEA 0xC0
0xEB 0xC3
0xEC 0x03
0xED 0x58
0xEE 0x85
0xEF 0xCA
0xF0 0xFF
0xF1 0x00
0x88 0x00
0x8A 0x0C
And I tried this with ADV7180-ADV7391 EVAL board but nothing wrong.
=> We are inputting the color bar with CVBS so the white is not 100%white but sync depth is almost 286mV.
So I think some thing is wrong with the connection to ADV7390 output.
=> We know that our customer connect 75Ohms to GND but don't know what is connect from there on.
I think if they use ADV7390 with "DACoutputLevel = default" , this shouldn't happen.
I mean in any case , ADV7390 will output the DAC signal with 286mV sync depth.
Is my understanding is correct?
Or can this happen by the input signal or something?
Also if you can give me some advice why the sync depth is small ( it look like the output gain is 75%) ,
it would help us and our customer.
Best regards.
Kawa
