dac8800FPZ glitch
Question asked by daliseau on Jun 26, 2011
Latest reply on Jul 5, 2011 by LiamR
I am using the old DAC8800 8 Channel DAC on a project, its pretty basic where I pass an 8 bit value to channel 1 of the DAC8800
The problem I have discovered is the ladder inside the chip appears to be incorrectly built.
Ie.
V1RH, V2RH, VDD set to 12v
V1RL, V2RL,/CLK, VSS set to 0V
/CLR set to +5v
SDI Data in
Clk Data In
Load on completion
Address 000 = Channel 1
Data 255     =     10.86v
Data 254     =     10.67v
Data 253     =     10.73v     - Voltage goes up
Data 252     =     10.46v
Data 251     =     10.61v     - Voltage goes up
Data 250     =     9.90v
Data 249     =     10.14v    - Voltage goes up
This appears to continue until we are less than decimal 64
To verify that my software is correct, I setup a breadboard with switches to manually verify this and the results were the same.
Any ideas??
Darren
The chips is labelled
DAC8800
F#0904
P1585598.1
