Zynq-7010(ZYBO board), (SSM2603 + i2s-axi + pl330 DMA), recording issues.
Question asked by jwplex on Feb 4, 2016
Latest reply on Feb 5, 2016 by larsc
Dear community,
I trying to implement linux sound device driver for Diligent ZYBO rev. B3 board based on Zynq-7010 + SSM2603 codec (connected to PL as slave, scheme is shown in system.pdf, I've only added 1 bit in CTRL reg for MUTE signal, other logic is the same as at Analog Devices github).
Adopted driver succesfully probed & bound:
zybo-ssm2603-snd zybo_ssm2603_snd: ssm2602-hifi <-> 43c00000.axi-i2s mapping ok
Source code (rewritten from Zed board) and patch on top of xcomm_zynq branch is provided (zybo_ssm2603.c attached separatly).
Playback works fine, but capture behave strange, instead of sound I heard only short beep (sound like after jack insertion in mic port) then digital silince (ssm2603_441kHz_cap.wav):
#arecord -D default:CARD=SSM2603 -r 44100 ssm2603_441kHz_cap.wav --dump-hw
Recording WAVE '/mnt/sdcard/ssm2603_cap.wav' : Unsigned 8 bit, Rate 44100 Hz, Mono
HW Params of device "default:CARD=SSM2603":
-------------------setsysclk ret: 0-
ACCESS:  MMAP_INTERLEAVED MMAP_NONINTERLEAVED MMAP_COMPLEX RW_INTERLEAVED RW_NONINTERLEAVED
FORMAT:  S8 U8 S16_LE S16_BE U16_LE U16_BE S24_LE S24_BE U24_LE U24_BE S32_LE S32_BE U32_LE U32_BE MU_LAW A_LAW I
MA_ADPCM S24_3LE S24_3BE U24_3LE U24_3BE S20_3LE S20_3BE U20_3LE U20_3BE S18_3LE S18_3BE U18_3LE U18_3BE
SUBFORMAT:  STD
SAMPLE_BITS: [4 32]
FRAME_BITS: [4 320000]
CHANNELS: [1 10000]
RATE: [4000 4294967295)
PERIOD_TIME: (666 4096000]
PERIOD_SIZE: (2 4294967295)
PERIOD_BYTES: (1 4294967295)
PERIODS: (0 2147483647)
BUFFER_TIME: [1 4294967295]
BUFFER_SIZE: [5 4294967294]
BUFFER_BYTES: [3 4294967295]
TICK_TIME: ALL
^CAborted by signal Interrupt...
arecord: pcm_read:2032: read error: Interrupted system call
I have tried different setups of alsamixers, check reg dump and compare with working ~baremetall~ program, everything look like codec driver works fine.
Q:
1) What should I check to make capture channel work?
Previously I tried to do the same on Xilinx kernel and got unstable work look like because of DMA.
2) Why in zybo_ssm2603_hw_params routine I recive only capable with 12.288 Mhz frequences, while I am asking `arecord` or `aplay` for 44.1kHz
Any suggestions are welcom,
Thansk in advance.
