ADDI7013 timing output?
Question asked by knkong0911 on Feb 2, 2016
Latest reply on Mar 4, 2016 by TFAnalog
Hi everyone,
We have tried to operate ADDI7013 and
found a problem that simulation result is not applied to device (ADDI7013).
Please advice to us to solve this problem.
And please recommend another new advanced part (or replacement of ADDI7013).
Please refer to attachment as below.
Kyungnam
The project information (@VisualTglde software) is as follwings.
VisualTglde Project
ISATG Part = ADDI7013
CLK_Signal = HBLK1, HBLK2, RGBLK1, CLPOB, PBLK
Pattern Editor = toggle_vector(33:HBLK1)(c); toggle_vector(0:HBLK2,RGBLK1)(r);toggle_vector(1067:HBLK1)(r);toggle_vector(0:HBLK2,RGBLK1)(r); rts;
VD_POS1 = 0
VD_POS2 = 105
HD_POS1 = 0
HD_POS2 = 80
VDLEN_mode0_field0 = 2331000
HDLEN_mode0_field0 = 1125
Simulation result by using VisualTglde tool is OK!
But the device ADDI7013 signal (VD & HD, H1 & H2) output is not the timing output as its simulation result.
(Simulation Result  --> OK!!!)
              ________
VD       _|               |______
              ______
HD       _|           |________
            ___          _______
HBLK1       |_____|
            ___          _______
HBLK2       |_____|
             _   ______   _   _
H1      _|  |_|           |_|  |_|  |_
          _   _             _   _    _
H2       |_|  |______|  |_|  |_|
(Device ADDI7013 Output --> HBLK1, HBLK2 effects is ???)
              ______          _____
VD       _|           |_____|
              ______          _____
HD       _|           |_____|
             _   _    _    _    _   _
H1      _|  |_|  |_|  |_|   |_|  |_|  |_
          _    _   _    _    _    _   _
H2        |_|  |_|  |_|  |_|   |_|  |_|
(afestartup.lf)
C022      0001       // software reset
C031      0001       // SCK_SELECT
C020      004F       // Enable AFE and REF
C021      0000       // CLI DIVIDE
C086      008b      // REQUIRED STARTUP WRITE
C087      0000       // REQUIRED STARTUP WRITE
C0A0      1000       // REQUIRED STARTUP WRITE
C0C0      0001       // REQUIRED STARTUP WRITE
C0C1      0048       // REQUIRED STARTUP WRITE
C020      005F       // Enable Timing core
C030      0001       // CLI SELECT wait at least 200 us after TG enable
C001      0002       // CDS Gain
C002      000F       // VGA Gain Channel 1
C003      000F       // VGA Gain Channel 2
C006      01EC      // CLAMPLEVEL A
C007      01EC      // CLAMPLEVEL B
C041      1800       // H1POSLOC,H1NEGLOC --> H1A OK
C042      1800       // H2POSLOC,H2NEGLOC --> H1B OK
C043      0018       // H3POSLOC,H3NEGLOC --> H2A OK
C044      0018       // H4POSLOC,H4NEGLOC --> H2B OK
C045      2000       // HL1POSLOC,HL1NEGLOC
C046      2000       // HL2POSLOC,HL2NEGLOC
C047      0006       // RG1POSLOC,RG1NEGLOC  --> RESET
C048      0006       // RG2POSLOC,RG2NEGLOC
C049      2000       // SHDLOC_A,SHPLOC_A
C04B      2000       // DOUTPHASEP,DOUTPHASEN
C04D      0000       // HBLKRETIME,HBLKPOL --> 0x5555 (?)
C04E      0000       // FINERETIME
C000      0241       // ENABLE BLACK CLAMP, SAMPLING MODE
C0CF      0003       // REQUIRED STARTUP WRITE
C027      0001       // MASTER MODE
7C0B      000F       // ISATGSTANDBY
7C0F      0002       // ISATG STARTUP write
7C80      0000
7C81      0000
7C82      000A
7C83      0000
7C88      0000
7C89      0000
7C8A      000A
7C8B      0000
7C74      0004       // ATIMER_SEL1
7C75      0000       // ATIMER_SEL2
7C60      FFFF
7C61      FFFF
7C64      FFFF
7C65      FFFF
7C70      FFFF
7C71      FFFF
7C72      FFFF
7C6C      0033
7C6D      0000
7C6E      0000
7C62      9C3F
7C63      0000
7C66      0F9F
7C67      0000
7C69      FFFF
7C6B      FFFF
7C68      FFFF
7C6A      FFFF
7C51      0000       // OUTSTANDBY1 STIMER[31:16]
7C52      AAFF     // OUTSTANDBY2 STIMER[47:32]
7C53      00FF       // OUTSTANDBY3 STIMER[63:48](Only Required for Simulation)
7C54      0000       // OUTSTANDBY4 ATIMER[15:0]
7C55      0000       // OUTSTANDBY5 ATIMER[31:16]
7C56      0000       // OUTSTANDBY6 ATIMER[47:32]
7C41      0000       // OUTREG1
7C42      AAFF     // OUTREG2
7C43      00FF       // OUTREG3(Only Required for Simulation)
7C44      0000       // OUTREG4
7C45      0000       // OUTREG5
7C46      0000       // OUTREG6
7C49      C000      // OUTEN1
7C4A      FFFF       // OUTEN2
7C4B      03FF       // OUTEN3(Only Required for Simulation)
7C4C      FFFF       // OUTEN4
7C4D      FFFF       // OUTEN5
7C4E      FFFF       // OUTEN6
C023      0000       // DISABLE VD/HD AS INPUTS
C024      0002       // ENABLE VD/HD AS OUTPUTS
C026      0001       // CONFIGURE SYNC PIN AS SYNC
C028      0000       // SYNCPOL/VDHDPOL/MSHUTPOL/VSUBPOL=0  --> 0x0000 (rising edge trigger)
C080      0000       // ENABLE LVDS OUTPUTS
C082      0071       // TCLK_DEL, DUAL PORT MODE --> 0x0071
C083      0060       // ENABLE CLIP_ZS, CLIP_FS, [1:0]=REQUIRED WRITE
C088      0006       // OUTPUT 6 SYNCWORDS, 0 CTRLWORDS
C089      0000       // SYNCWORD0
C08A      0000       // SYNCWORD1
C08B      FFFF       // SYNCWORD2
C08C      FFFF       // SYNCWORD3
C08D      0000       // SYNCWORD4
C08E      0000       // SYNCWORD5
C097      0003       // CWB0=HD
C099      0001       // RISING EDGE TRIGGER ON CWB0
C025      00FF       // ONLY FOR SIMULATION (not required for actual device) --> 0x0000 (?)
C02F      0050       // SDATA out for register read-back mode
(tgstartup.lf)
C024      00FE       // ENABLE DATA, GPO
C058      4444       // H1 Driver Strength
C059      4444       // H2 Driver Strength
C05A      4444       // H3 Driver Strength
C05B      4444       // H4 Driver Strength
C05C      4444       // HL1 Driver Strength
C05D      4444       // HL2 Driver Strength
C05E      4444       // RG1 Driver Strength
C05F      4444       // RG2 Driver Strength
4000       0000                       // Set Mode 0
7c34       0018                       // ISR jump to 24
7c22       0000       // ILAT (CLEAR INTERRUPTS)
7c20       FFEF       // enable interupts
7c22       0010       // ILAT to trigger VD ISR
