facing problem with adv7401 configuration
Question asked by monu on Feb 2, 2016
Latest reply on Feb 11, 2016 by DerekBurke
hi,
i am using below given statements for configuration of ADV7401 using I2C interface. i have found that two of the registers are not getting updated by the value required. Please help.
i/p to ADV7401 is COMPONENT RGB 512x576 interlaced (signal looks like PAL, 2Vpp), HS= 64usec, VS=20msec,pixel clock= 13.5MHz
.G is on Ain6 and rest (R,B) are grounded. (digital output for G only is needed)
output required:
24 bit rgb digital output for same resolution (or higher if possible). LLC1 = 55.3MHz, samples required per line = 2880.
code section dealing I2C commands for configuration of ADV7401:
void Configure_Decoder(unsigned char slave) // this is for default values update
Write_to_Decoder(slave,0x00,0x0A);
Write_to_Decoder(slave,0x05,0x01);
Write_to_Decoder(slave,0x1D,0x47);
Write_to_Decoder(slave,0x3A,0x21);
Write_to_Decoder(slave,0x3B,0x80);
Write_to_Decoder(slave,0x6B,0xC2)
Write_to_Decoder(slave,0x7B,0x05);
Write_to_Decoder(slave,0x85,0x19);
Write_to_Decoder(slave,0x86,0x0B);
Write_to_Decoder(slave,0x8A,0xD0);
Write_to_Decoder(slave,0xC5,0xC1);
Write_to_Decoder(slave,0xF3,0x0F);
Write_to_Decoder(slave,0xF4,0x3F);
Write_to_Decoder(slave,0xB7,0x12);
value = Read_from_Decoder(slave,0x8F);
Configure_Decoder_STANAGB(slave);
void delay(void)
unsigned char i;
for(i=0;i<1000;i++);
// this function is for STANAGB setting
void Configure_Decoder_STANAGB(unsigned char slave)
Write_to_Decoder(slave,0x06,0x03);
Write_to_Decoder(slave,0x3C,0x5C);
Write_to_Decoder(slave,0x87,0xFB);
Write_to_Decoder(slave,0x88,0x40);
Write_to_Decoder(slave,0x90,0xC0);     //NOT GETTING UPDATED, SHOWS DEFAULT VALUE ON READ BACK
Write_to_Decoder(slave,0x8F,0x06);     // NOT GETTING UPDATED, SHOWS DEFAULT VALUE ON READ BACK
Write_to_Decoder(slave,0x7C,0xC0);
Write_to_Decoder(slave,0x7E,0x00);
Write_to_Decoder(slave,0x73,0x12);
Write_to_Decoder(slave,0x8D,0x03);
Write_to_Decoder(slave,0xF9,0x04);
Write_to_Decoder(slave,0xC4,0x80);
Write_to_Decoder(slave,0xC3,0x06);
Write_to_Decoder(slave,0x6A,0x10);
Write_to_Decoder(slave,0x68,0x01);
value = Read_from_Decoder(slave,0x90);
