AD9833 Perfect Square wave but no Triangle or Sin
Question asked by CollegeProjects on Jun 26, 2011
Latest reply on Jul 5, 2011 by CollegeProjects
Hey EngineerZone,
I am attemping to program an AD9833 using a PIC18F2525 and its SPI Interface.
I can succefully get a Nice & Clean Square wave out of VOUT at different Frequencies, but the moment I change the Control Word to select ether a Sin or Triangle selection, VOUT goes to 0 Volts flat line.
The AD9833 is wired up as the following :
http://hades.mech.northwestern.edu/images/f/fc/AD9833Connsmall.jpg
I do not think its a SPI communication problem because anything to do with square wave works perfectly. Made sure with a scope that that correct data from SDATA is indeed being applied on each Falling Edge of SCLK; which is the case.
At first I Thought it was my Control Word Settings that were incorrect but after using the same Data given from the AD9833 Device Configuration Assistant(http://designtools.analog.com/dt/ad98334/ad9833.html) the same results are atteined EG. Anything to do with Square Wave works fine, but Sin & Triangle nothing at VOUT.
Here is my Snippit of code that has to do with AD9833 Comunication:
ChipSelect = 1;
SPI_COM(unsigned char Wave_Count)
   // Calculation();
    SPI_Packet[0] = 0x2120; // Enable Reset Set for SquareWave
    SPI_Packet[1] = 0x50C7; /*FreqLSB;*/
    SPI_Packet[2] = 0x4000; /*FreqMSB;*/
    SPI_Packet[3] = 0xC000; // Write to Phase Register 0
    SPI_Packet[4] = 0x2020; // Remove Reset Set for SquareWave
    while(SPI_Packet_Count != 5)
        SPI_Out(SPI_Packet[SPI_Packet_Count]);
        SPI_Packet_Count++;
    SPI_Packet_Count = 0;
SPI_Out(unsigned int DataWord)
unsigned char Bytes[2];
unsigned char count = 0;
unsigned char Bytes_Buffer = 0;
Bytes[0] = DataWord >> 8;
DataWord = DataWord << 8;
Bytes[1] = DataWord >> 8;
    ChipModeSelect(0);
    SSPBUF = Bytes[0];
        while(PIR1bits.SSPIF == 0)
    PIR1bits.SSPIF = 0;
    SSPBUF = Bytes[1];
    PIR1bits.SSPIF = 0;
    ChipModeSelect(1);
//Turns on Correct FSYNC Pin(My Project will have 2 AD9833 to communicate with)
ChipModeSelect(unsigned char done)
if(done == 1)
    PORTCbits.RC1 = 1;
    PORTCbits.RC2 = 1;
    done = 0;
else
        if(ChipSelect == 1)
            PORTCbits.RC2 = 0; //AD9833 1
        else
            PORTCbits.RC1 = 0; //AD9833 2
Essentialy in this Example I should only have to change the Control Word in SPI_Packet[0] & SPI_Packet[4] respectivly to (0x2100) &(0x2000) for Sin Wave and (0x2102) & (0x2002) for Triangle, correct?(According to AD9833 Device Configuration Assistant and Data Sheet) But this is not the case.
Has anyone had a problem such as this?
Any help is appricated, this is the only thing stopping me from sending my project from Alpha to the Beta Stage.
Thank You,
Patrick.
