ADE7763 Trying to zero the offset registers
Question asked by james1111 on Feb 2, 2016
Latest reply on Feb 5, 2016 by hmani
Hi there,
I have my project mostly working however when there is no voltage on CH1 for IRMS I get some channels (I have 8) read like 1.2 & 3.7A and I would like to zero these, if I set the register CH1OS to 0x00 at first initialization it makes no difference.
Where I do my regular V & I read,
  • I config the chip for IRMS,
  • set the register CH1OS to 0x00 &
  • read the IRMS
This is now reading low, like 0.1A which is fine, however when I turn the mains voltage supply on I measure no V but 80 Amps, if I comment out the offset register write it ready V normally again, but the offset goes back to 1-4V
// ADE7763 definitions
#define READ_MODE_REG   0x09
#define WRITE_MODE_REG  0x89
#define CURRENT         0x58
#define VOLTAGE         0x78
#define SETTINGS        0xAD    // break out into seperate bits later on
#define SET_GAIN        0x8F
#define SET_I_OFFSET    0x0D
#define SET_V_OFFSET    0x0E
#define FULL_RANGE      0x00    // +/-500mV
#define IRMS            0x16
#define VRMS            0x17
#define FREQ            0x27
#define TRUE            1
#define FALSE           0
#define DELAY_BETWEEN_READINGS 10
uint8_t config_ade7763_VRMS(uint8_t i)
    cs_low(i);
    _delay_us(4);
    writeSPI1(WRITE_MODE_REG);  // 89
    _delay_us(30);
    writeSPI1(VOLTAGE);         // 78
    _delay_us(30);
    writeSPI1(SETTINGS);        // AD
    _delay_us(30);
    cs_high(i);
    _delay_us(DELAY_BETWEEN_READINGS);
uint8_t config_ade7763_IRMS(uint8_t i)
    cs_low(i);
    _delay_us(4);
    _delay_us(30);
    writeSPI1(CURRENT);
    _delay_us(30);
    _delay_us(30);
    cs_high(i);
    return TRUE;
uint8_t config_ade7763_Voffset(uint8_t i)
    cs_low(i);
    _delay_us(4);
    _delay_us(30);
    writeSPI1(SET_V_OFFSET);
    _delay_us(30);
    writeSPI1(0x00);            // zero the current offset in ch 2
    _delay_us(30);
    cs_high(i);
uint8_t config_ade7763_Ioffset(uint8_t i)
    cs_low(i);
    _delay_us(4);
    _delay_us(30);
    writeSPI1(SET_I_OFFSET);
    _delay_us(30);
    writeSPI1(0x00);                // zero the current offset in ch 1
    _delay_us(30);
    cs_high(i);
uint8_t config_ade7763_range(uint8_t i)
    cs_low(i);
    _delay_us(4);
    writeSPI1(SET_GAIN);    // 8F
    _delay_us(5);
    writeSPI1(FULL_RANGE);  // 00
    _delay_us(15);
    cs_high(i);
void ade7763_init(void)
    uint8_t i=0;
    for( i=0; i<8; i++)
        config_ade7763_VRMS(i);
        _delay_ms(1);
//        config_ade7763_Voffset(i);
        _delay_ms(1);
        config_ade7763_range(i);
        _delay_ms(1);
        config_ade7763_IRMS(i);
        _delay_ms(1);
        config_ade7763_Ioffset(i);
        _delay_ms(1);
        _delay_ms(1);
for( v=0; v<4; v++)
     config_ade7763_VRMS(v);
     config_ade7763_range(v);
     config_ade7763_Voffset(v);
     read_ade7763_VRMS(v);
for( i=0; i<4; i++)
     read_ade7763_IRMS(i);
Any ideas why this is happening please?
Thanks in advance..
