ADV7393 YPbPr PAL Color Bar Out to ADV7403 4:4:4 24 Bit Output
Question asked by JeffStearns on Feb 1, 2016
Latest reply on Feb 2, 2016 by JeffStearns
We are developing a test program for our customer on an ATE Test Station to test an ADV7393 analog YPbPr output feeding a ADV7403 which outputs 4:4:4 24 bits through to a Xilinx FPGA which we control to capture the data in a buffer which will then be tested.  The schematic page for the ADV7403 is attached.  We have had success testing the AIN4 composite PAL color bar in to the ADV7403 from the ADV7393 to 16 Bit output with the following scripts:
##COMPOSITE PAL COLOR BAR ADV7393 to ADV7403 AIN4##
#ADV7393 Script#
54 00 1C ; POWER_MODE register , Power On DAC 1, 2, and 3, PLL Enable, Sleep Mode Off
54 80 11 ; VIDEO_STANDARD register, Active Video Edge Control, SD Pixel Data Valid
54 82 CB ; SD_MODE_2 register, Composite, Active Video Edge Control, SD Pixel Data Valid
54 84 40 ; SD_MODE_4 register, SD Color Bars Enabled
54 8c cb ; SD_FSC_0 register, Table 37, PAL Typical FSC Values
54 8d 8a ; SD_FSC_1 register, PAL Typical FSC Values
54 8e 09 ; SD_FSC_2 register, PAL Typical FSC Values
54 8f 2a ; SD_FSC_3 register, PAL Typical FSC Values
#ADV7403 Script#
:AUTODETECT CVBS IN NTSC/PAL/SECAM, 16-Bit YPbPr 422 out through encoder :
42 00 03 ; CVBS Ain4, without pedestal, auto detect PAL
42 03 08 ; 16 Bit Mode
42 17 41 ; select SH1
42 1D 47 ; Enable 28MHz Crystal
42 3A 17 ; Set Latch Clock & power down ADC 1 & ADC2 & ADC3
42 3B 80 ; Enable External Bias
42 2B E1 ; Color Kill Enable
42 31 02 ; Clears NEWAV_MODE, SAV/EAV  to suit ADV video encoders
42 3D A2 ; MWE Enable Manual Window, Colour Kill Threshold to 2
42 3E 6A ; BLM optimisation
42 3F A0 ; BGB
42 86 0B ; Enable stdi_line_count_mode
42 F3 01 ; Enable Anti Alias Filter on ADC0
42 F9 03 ; Set max v lock range
42 0E 80 ; ADI Recommended Setting
42 52 46 ; ADI Recommended Setting
42 54 00 ; ADI Recommended Setting
42 7F FF ; ADI Recommended Setting
42 81 30 ; ADI Recommended Setting
42 90 C9 ; ADI Recommended Setting
42 91 40 ; ADI Recommended Setting
42 92 3C ; ADI Recommended Setting
42 93 CA ; ADI Recommended Setting
42 94 D5 ; ADI Recommended Setting
42 B1 FF ; ADI Recommended Setting
42 B6 08 ; ADI Recommended Setting
42 C0 9A ; ADI Recommended Setting
42 CF 50 ; ADI Recommended Setting
42 D0 4E ; ADI Recommended Setting
42 D1 B9 ; ADI Recommended Setting
42 D6 DD ; ADI Recommended Setting
42 D7 E2 ; ADI Recommended Setting
42 E5 51 ; ADI Recommended Setting
42 0E 00 ; ADI Recommended Setting
We are having trouble when we set the ADV7393 for YPbPr PAL Color Bar outputs to the ADV7403 set up for YPbPr inputs and 24 bit output setup.  Could you give us recommendations for modifying the scripts above to accomplish the YPbPr ADV7393 Color Bar outputs and 24 bit output from the ADV7403?
Any help would be greatly appreciated.
Jeff Stearns
