about HMC834 SPI write and eval-board clk
Question asked by jay1 on Jan 26, 2016
Latest reply on Feb 10, 2016 by dyoung1
hi
I'm recently working with the Hittite HMC834(PLL with integrated VCO).
i'm a new starter about this field, and i have some questions about SPI writing
1.i found out that the length of the register(to write) is not a multiple of the 8. thus i made some signal with the GPIO pins. this is available?(about 100 KHz clk)
2.when i check the evaluation software, and i've found that the eval-software offers the register value as below
REVISION 3.2.4.0
REG 0 A7975
REG 1 2
REG 2 1
REG 3 50
REG 5 6090
REG 6 2003CA
REG 7 14D
REG 8 C1BEFF
REG 9 147FFF
REG A 2046
REG B 7C061
REG C 0
REG D 0
REG E 0
REG F 1
REG 10 39
REG 11 80013
REG 12 3
REG 13 1259
REG 14 0
REG 15 0
REG 16 0
REG 17 0
REG 18 0
REG 19 0
REG 1A 0
REG 1B 0
REG 1C 0
REG 1D 0
REG 1E 0
REG 1F 0
REG 4 0
XTAL 50
DIVIDER_MANUAL_MODE 0
VCO_TO_SYNTH_DIV 1
VCO_TO_OUT_DIV 1
upper one is just example,
if i send the register values, from reg00 to reg 1F, it will properly work?
3. when i check the Datasheet of the HMC834, registers do not have the address about the each register(only values).
for example, i found out that reg00 and reg04 is 24bit, if i send the 24 bit data, i cannot sure that which register will recieve the 24bit data.
is there any sequence to write?
4. it has the 50MHz clk on the eval board. when i put the 10MHz reference clk on the ref port(SMA), the PLL is working with the 50MHz?
the clk applied to the HMC834 IC is only controllable with the SW1 switch with the eval board?
