AD8304 noise estimation
Question asked by tneagoe on Jan 26, 2016
Latest reply on Feb 1, 2016 by jdobler
I am just reviewing the spec sheet of this device and am looking for some feedback on noise estimation at 1-KHz to determine ADC performance.
The shaded table cells are my estimation from the graph data
From graph 9 on page 5 of the datasheet…review of 1-KHz noise data
FROM GRAPH 9 (page 5)
ESTIMATED VALUES FROM GRAPH DATA
Input Current
1-KHz (uV/rtHz) from graph
Calculated 1-KHz Noise (mVrms)
Calculate Total RMS LSBs (VREF =5)
1-nA
40
  1. 1.3
3846 (or 11.9-Bits)
10-nA
6
  1. 0.19
26315 (or 14.7-Bits)
100-nA
1
  1. 0.032
Ok
1-uA
~0.18
  1. 0.0057
Ok
10-uA
~0.15
  1. 0.0047
Ok
>100-uA
~0.15
  1. 0.0047
Ok
Questions:
  1. Are my estimations accurate from the graph data.
  2. Is the 1-KHz graph data based on a single pole LPF at VLOG?
  3. Graphs 2 and 3 on datasheet page 4 indicate the use of a small negative supply (VN) to provide the performance indicated.  Is there a significant degradation if VN is 0-Volts?
  4. It seems that 100-pA is the minimum spec input current yet there is a provision to move the intercept lower as indicated on page 11..showing effective intercepts down to 1-pA
    Can Analog devices indicate the noise performance in the 1-pA to 1-nA range using this technique…like the graphs of 8 & 9?
Regards, TN
