ADV7842 TMDS PLL Sometimes Not Locking
Question asked by DRC on Jun 22, 2011
Latest reply on Jun 27, 2011 by GuenterL
I'm reading back the following registers:
TMDS_PLL_LOCKED ([HDMIMap][0x04][1])
TMDSPLL_LCK_A_RAW ([IOMap][0x6A][5])
TMDS_CLK_A_RAW ([IOMap][0x6A][1])
I used the script posted in the following:
http://ez.analog.com/message/15410#15410
At first, everything is fine and all 3 status registers are set to 1.
When I unplug and replug my cable (without making any configuration changes), often the two PLL-Lock status bits are set to 0 and are stuck like that.  TMDS_CLK_A_RAW (the bit that tells you if a clock is detected) is always 1 when the cable is plugged in.
So it appears sometimes the TMDS PLL is not locking.  If I reset the ADV7842 and reconfigure it using the script, everything is fine.
I also noticed that if I probe the clock signal on my board with my scope (using an active probe), the PLL locks immediately and the two status bits are now 1.  Hopefully that's a clue.
Is there something I'm missing here?  Do I need to reset the PLL somehow?
Let me know if you need any more info or measurements.
Thanks
