Question:Build rootfs for BF609
Question asked by SmartIC on Jan 21, 2016
Latest reply on Jan 25, 2016 by WillMoore
Host Linux:Ubuntu 14.04 LTS
toolchain:
blackfin-toolchain-2014R1-RC2.x86_64
blackfin-toolchain-elf-gcc-4.3-2014R1-RC2.x86_64
blackfin-toolchain-uclibc-full-2014R1-RC2.x86_64
Rootfs:
Step1: make clean;make bf609-ezkit_defconfig
Then message:
parallels@ubuntu:~/blackfin/blackfin-buildroot$ make bf609-ezkit_defconfig
mkdir -p /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/lxdialog
make CC="/usr/bin/gcc" HOSTCC="/usr/bin/gcc" obj=/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config -C support/kconfig -f Makefile.br conf
make[1]: Entering directory `/home/parallels/blackfin/blackfin-buildroot/support/kconfig'
/usr/bin/gcc -DCURSES_LOC="<ncurses.h>" -DLOCALE  -I/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config -DCONFIG_=\"\"  -MM *.c > /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/.depend 2>/dev/null || :
make[1]: Leaving directory `/home/parallels/blackfin/blackfin-buildroot/support/kconfig'
/usr/bin/gcc -DCURSES_LOC="<ncurses.h>" -DLOCALE  -I/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config -DCONFIG_=\"\"   -c conf.c -o /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/conf.o
/usr/bin/gcc -DCURSES_LOC="<ncurses.h>" -DLOCALE  -I/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config -DCONFIG_=\"\"  -I. -c /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/zconf.tab.c -o /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/zconf.tab.o
In file included from /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/zconf.tab.c:2500:0:
./confdata.c: In function ‘conf_split_config’:
./confdata.c:849:6: warning: assignment makes pointer from integer without a cast [enabled by default]
  dir = dirname(_name);
/usr/bin/gcc -DCURSES_LOC="<ncurses.h>" -DLOCALE  -I/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config -DCONFIG_=\"\"   /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/conf.o /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/zconf.tab.o  -o /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/conf
rm /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/zconf.tab.c
# configuration written to /home/parallels/blackfin/blackfin-buildroot/.config
Step2:make
Then message:
/usr/bin/make -j3  HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" silentoldconfig
make[1]: Entering directory `/home/parallels/blackfin/blackfin-buildroot'
BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/tristate.config BUILDROOT_CONFIG=/home/parallels/blackfin/blackfin-buildroot/.config /home/parallels/blackfin/blackfin-buildroot/output/build/buildroot-config/conf --silentoldconfig Config.in
make[1]: Leaving directory `/home/parallels/blackfin/blackfin-buildroot'
mkdir -p /home/parallels/blackfin/blackfin-buildroot/output/target
rsync -a \
  --exclude .empty --exclude .svn --exclude .git \
  --exclude .hg --exclude=CVS --exclude '*~' \
  "board/AnalogDevices/blackfin/target_skeleton"/ /home/parallels/blackfin/blackfin-buildroot/output/target/
cp support/misc/target-dir-warning.txt /home/parallels/blackfin/blackfin-buildroot/output/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
touch /home/parallels/blackfin/blackfin-buildroot/output/build/.root
>>>   Checking external toolchain settings
IPv6 support available in C library, please enable BR2_INET_IPV6
make: *** [/home/parallels/blackfin/blackfin-buildroot/output/stamps/ext-toolchain-checked] Error 1
How to solve it? Thanks.
