Accessing .ldf symbols
Question asked by STWisdom on Jun 22, 2011
Latest reply on Jun 23, 2011 by STWisdom
Hi there!
I am writing software for a Blackfin BF525. I am implementing some code where I would like to get the address of the beginning of the memory region allocated to the stack. What I tried initially was to access the symbols ldf_stack_space and ldf_stack_end from a C source file by including the lines
extern "asm" int ldf_stack_space;
extern "asm" int ldf_stack_end;
at the top of my C file below the include directives. However, when I try to make an assignment in a function, i.e.
void function1()
     int stackPointer;
     stackPointer = ldf_stack_space;
, stackPointer is not getting the value of ldf_stack_space. Now, I have been looking through documentation on how I might be able to access the .ldf symbols in my source code. I am certainly able to access the symbols in my startup code, basiccrt.s, by using the directive .extern ldf_stack_space. I also tried including the lines
.global ldf_stack_space
in the basiccrt.s file in a user-code preserving section, but still no dice. I have also tried adding mangled names to the .ldf by including this code in the user-code preserving section:
_ldf_stack_space = ldf_stack_space;
_ldf_stack_end = ldf_stack_end;
So, is it even possible to access .ldf symbols in source code? If so, how?
Thank you very much!
-SW
