ad1939 ADC slots data format
Question asked by Shamsul on Jan 20, 2016
Latest reply on Jan 26, 2016 by Shamsul
I am using blackfin BF532 to interface ad1939. I have configured the codec by spi and it outputs the adc data via the sport interface to the blackfin through interrupt. This interrupt service routine is executed after a complete frame of input data has been received from the sport interface. Mine is 48kHz sampling rate, I am using PLL to clock out ADC data, source of PLL is 12.288Mhz clock feeded into MCLK pin of CODEC. Also I am using TDM Aux mode in my ADC channels
Now from AD1939 datasheet I know full scale differential input is 1.9Vrms. So I am trying to do very simple thing here just to get things started.
On my input pins of ADC channel 1, (ADC_L1  slot1 of TDM data streem) (pin 53, pin 54)
I am putting on 2.5V DC and 0.65V DC respectively to get full scale digital output in my TDM slot 1
Then putting on 1.5V DC and 1.5V DC respectively to get 0 digital output in my TDM slot
If I look into Visual DSP++ debugger expression window I see it gives 2s compliment value which are ok.
Now If I put this same dc voltage (2.5/0.65 & 1.5V/1.5V DC) on ADC channel 2 (which should be ADC_R1 SLOT2 in TDM stream ) I see that 2s compliment value is not consistent all the time. I put a break point in my ISR routine and I see that correct 2s compliment value do not show up all the time  & it gives some garbage value in between for ADC 2 channel. However I don’t see this problem on ADC channel 1
What might be the reason for ADC channel 2 not to give consistent 2s compliment value?
Also just to be sure that I am doing right, I am taking that 2s compliment value converting to decimal then using this equation to get actual voltage
(decimal value x 1.9V)/(2^23 -1)
Please let me know if this calculation is right or not.
Following is my register setting for CODEC 1939 and blackfin SPORT configuration
  {  PLL_CONTROL_0      , 0x98 } , //80
  {  PLL_CONTROL_1      , 0x08 } ,//00
  {  DAC_CONTROL_0      , 0x80 } , // 1 bit delay
  {  DAC_CONTROL_1      , 0x74 } , //74
  {  DAC_CONTROL_2      , 0x00 } , // no confusion
  {  DAC_Channel        ,      0x00 } , // no confusion
  {  DAC_VOLUME_1       , 0xFF } ,
  {  DAC_VOLUME_2       , 0xFF } ,
  {  DAC_VOLUME_3       , 0xFF } ,
  {  DAC_VOLUME_4       , 0xFF } ,
  {  DAC_VOLUME_5       , 0xFF } ,
  {  DAC_VOLUME_6       , 0xFF } ,
  {  DAC_VOLUME_7       , 0xFF } ,
  {  ADC_CONTROL_1      , 0x00 } , // no confusion
  {  ADC_CONTROL_2      , 0x40 } ,
  {  ADC_CONTROL_3      , 0xe8 } // d8
#define INTERNAL_ADC_L0                                        0
#define INTERNAL_ADC_R0                                        1
#define INTERNAL_ADC_L1                                        2
#define INTERNAL_ADC_R1                                        3
#define INTERNAL_DAC_L0                                        0
#define INTERNAL_DAC_R0                                        1
#define INTERNAL_DAC_L1                                        2
#define INTERNAL_DAC_R1                                        3
#define INTERNAL_DAC_L2                                        4
#define INTERNAL_DAC_R2                                        5
void Init_Sport0(void)
                // Sport0 receive configuration
                // External CLK, External Frame sync, MSB first
                // 32-bit data
                *pSPORT0_RCR1 = RFSR;
                *pSPORT0_RCR2 = SLEN_32;
                // Sport0 transmit configuration
                // 24-bit data
                *pSPORT0_TCR1 = TFSR;
                *pSPORT0_TCR2 = SLEN_32;
                // Enable MCM 8 transmit & receive channels
                *pSPORT0_MTCS0 = 0x000000FF;
                *pSPORT0_MRCS0 = 0x000000FF;
                // Set MCM configuration register and enable MCM mode
                *pSPORT0_MCMC1 = 0x0000;
                *pSPORT0_MCMC2 = 0x101c;
void Init_DMA(void)
                // Set up DMA1 to receive
                // Map DMA1 to Sport0 RX
                *pDMA1_PERIPHERAL_MAP = 0x1000;
                // Configure DMA1
                // 32-bit transfers, Interrupt on completion, Autobuffer mode
                *pDMA1_CONFIG = WNR | WDSIZE_32 | DI_EN | FLOW_1;
                // Start address of data buffer
                *pDMA1_START_ADDR = (void *)iRxBuffer1;
                // DMA inner loop count
                *pDMA1_X_COUNT = 8;
                // Inner loop address increment
                *pDMA1_X_MODIFY     = 4;
                // Set up DMA2 to transmit
                // Map DMA2 to Sport0 TX
                *pDMA2_PERIPHERAL_MAP = 0x2000;
                // Configure DMA2
                // 32-bit transfers, Autobuffer mode
                *pDMA2_CONFIG = WDSIZE_32 | FLOW_1;
                *pDMA2_START_ADDR = (void *)iTxBuffer1;
                *pDMA2_X_COUNT = 8;
                *pDMA2_X_MODIFY     = 4;
void Enable_DMA_Sport0(void)
                // enable DMAs
                *pDMA2_CONFIG           = (*pDMA2_CONFIG | DMAEN);
                *pDMA1_CONFIG           = (*pDMA1_CONFIG | DMAEN);
                // enable Sport0 TX and RX
                *pSPORT0_TCR1 = (*pSPORT0_TCR1 | TSPEN);
                *pSPORT0_RCR1 = (*pSPORT0_RCR1 | RSPEN);
EX_INTERRUPT_HANDLER(Sport0_RX_ISR)
                // confirm interrupt handling
                *pDMA1_IRQ_STATUS = 0x0001;
                // copy input data from dma input buffer into variables
                iChannel0LeftIn = iRxBuffer1[INTERNAL_ADC_L0];
                iChannel0RightIn = iRxBuffer1[INTERNAL_ADC_R0];
                iChannel1LeftIn = iRxBuffer1[INTERNAL_ADC_L1];
                iChannel1RightIn = iRxBuffer1[INTERNAL_ADC_R1];
                D = ((iChannel0LeftIn)*1.9)/(2^23 - 1); // iChannel0LeftIn is converted from 2s compliment to decimal
So I am putting break point just after D value and seeing those 2st compliment value over this local register (iChannel0LeftIn, iChannel0RightIn )
So for channel one iChannel0LeftIn gives proper 2s compliment value which does not change. however iChannel0RightIn does not give consistent 2s compliment value, shows some garbage value on VisualDSP++ debugger.
Thanks for your time!
Shamsul Siddiqui
