Load rootfs from SD card
Question asked by 3DeeMoN on Jan 19, 2016
Latest reply on Jan 20, 2016 by Aaronwu
Hi!
Now I'm trying to make system which will run u-boot from SPI flash and then load kernel and rootfs from SD card.
Loading u-boot from SPI flash is ok. Loading kernel from SD is ok too: just "ext2load mmc 0 0x1000000 /boot/vmImage" in u-boot. I also set environment variable
setenv bootargs 'root=/dev/mmcblk0p1 rootwait rw clkin_hz=25000000 earlyprintk=serial,uart0,57600 console=ttyBF0,57600'
But mounting rootfs fails with this:
[   17.456874] mmc0: host does not support reading read-only switch. assuming write-enable.
[   17.474607] Warning: unable to open an initial console.
[   17.485305] Waiting for root device /dev/mmcblk0p1...
[   17.495420] mmc0: new SDHC card at address 0001
[   17.505972] mmcblk0: mmc0:0001 00000 3.79 GiB
[   17.517260]  mmcblk0: p1
[   17.599437] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
[   17.615996] Hardware Trace:
[   17.621609]    0 Target : <0x0024df20> { _dump_stack + 0x0 }
[   17.632899]      Source : <0x0024dfce> { _panic + 0x6a } CALL pcrel
[   17.645435]    1 Target : <0x0024dfbc> { _panic + 0x58 }
However I can mount rootfs manually when I boot uImage
root:/> mount /dev/mmcblk0p1 /mnt
[   53.155654] EXT2-fs (mmcblk0p1): warning: mounting unchecked fs, running e2fsck is recommended
I prepare SD card with this commands
sudo sfdisk --in-order --Linux --unit M /dev/sdb <<-__EOF__
1,,L,*
__EOF__
sudo mkfs.ext2 /dev/sdb1 -L rootfs
sudo tar xfp ./output/images/rootfs.tar -C /media/user/rootfs/
sudo mkdir /media/user/rootfs/boot
sudo cp ./output/images/vmImage /media/user/boot/vmImage
I tried ext4 and ext2 FS. Both mounts manually, but none on startup process. What should I check?
By the way, can I load u-boot and kernel with rootfs from the same sdcard? I found that I should put u-boot at 0 sector on SD, but partition table also should be at 0 sector.
