VisualDSP++ corruption
Question asked by stevet1976 on Jun 22, 2011
Latest reply on Jun 22, 2011 by CraigG
When I start Visual DSP++ I get an error
"Failed to create memory window because the following memory type does not exist in the target hardware Data(DM) memory"
Visual DSP++ will start after this error but I can not connect to a session I get the following error
"An invalid argument was encountered"
I get the same error when I try to exit VisualDSP++.
To kill the application, I have to go to windows task manager and kill the application, which still generates the invalid argument error but does also kill the application.
I am using VisualDSP++ v5.0 with update 9, running on Windows XP.
My target is Sharc21469. The problem started when I powered off my target hardware(custom board) before closing the connection. I have done this many times before and got the standard JTAG can't talk to the hardware errors, but Visual DSP++ has not been corrupted before and has restarted OK.
Are there any files that can easily be repaired that would cause this error or do I need to go for a re-install.
Thanks
Steve Tostevin
