BF607 core1 PWM interrupt via SEC
Question asked by AlexanderDeurloo on Jan 14, 2016
Latest reply on Jan 21, 2016 by AlexanderDeurloo
I have a PWM signal and need an interrupt every period.
I configured the PWM module such, that it indeed generates one, see result below:
pwm imask = 0x00100000  (PWM TMR4 period)
pwm latch = 0x00100000   (once the pwm runs, the corresponding bit goes hi, so an interrupt is really generated)
The ID for PWMTMR interrupt is 28 (0x1C)
So I configured the SEC accordingly:
bfin_write32(SEC0_GCTL, 0x2);    // reset
bfin_write32(SEC0_CCTL1, 0x2);    // reset
bfin_write32(SEC0_CCTL1, 0x1);    // enable
*pREG_SEC0_SCTL28 = (1<<24) | (0<<3) | (1<<2);        // core1, level sensitive, source signal enable
*pREG_SEC0_SCTL28 = (1<<24) | (0<<3) | (1<<2) | 0x01;    // interrupt enable
bfin_write_PWM0_IMSK(1<<20);    // unmask interrupt on TMR4PER
bfin_write_PWM0_DL0(Pwm_Nmi_CountMax-1);
bfin_write_PWM0_ILAT(1<<20);    // clear latch (better safe than sorry)
bfin_write32(SEC0_GCTL, 0x1);    // enable the SEC
bfin_write_PWM0_CTL(0x20001);    // Enable PWM module
evt11 is pointing to my ISR routine. But is seems that the interrupt signal gets lost somewhere in the SEC module.
The result is:
pREG_SEC0_SSTAT28 = 0x00000100  (bit9 = active source)
pREG_SEC0_SCTL28  = 0x0100000d   (core1, source enabled, interrupt enabled)
pREG_SEC0_CGMSK1 = 0x00000000  (nothing masked)
pREG_SEC0_CCTL1 = 0x00000001     (enabled)
pREG_SEC0_CPND1 = 0x0000001c     (clearly ID=28=PwmTmr4 period, so the PWM interrupt is received by the SEC)
pREG_SEC0_CACT1 = 0x00000000     (??? I expected this to be 0x1C as well)
pREG_SEC0_CPMSK1 = 0x000000ff    (no prio masking)
pREG_SEC0_CPLVL1 = 0x00000007    (all levels)
pREG_SEC0_CSTAT1 = 0x00000500    (SID valid, Pending valid, but Active is not valid !!)
pREG_SEC0_CSID1 = 0x0000001c      (SID = 0x1C, so correct)
CEC_SID = 0x0000001c
pREG_SEC0_GCTL = 0x00000001
pREG_SEC0_GSTAT = 0x00000000   (nothing received ???)
pREG_SEC0_RAISE = 0x00000000
pREG_SEC0_END = 0x00000000
I'm out of ideas. Did I configure something wrong or did I forgot something?
Thanks in advance,
Alexander.
