About ADV7441A TMDS Equalization Register Setting
Question asked by Eason_Excelpoint on Jan 13, 2016
Latest reply on Jan 18, 2016 by Eason_Excelpoint
Dear friends,
We have used ADV7441A as the DVI/PAL decode for our video process system, but we have the following issue, could you give some comments about the issue:
1) We found there are some light lines on the ADV7441A output image, the light lines apprearence time and position is random, the
    detail as following:
2) We have done the following confirmation:
    a. The source direct display in the LCD is OK;
    b. Short the transmit cable length, the light line will be disappear;
    c. Refer to the following TMDS Equalizer setting:
        We manually adjust the TMDS equalization register setting, if we configure the following register value, the issue also can be
        solved:
        For TMDS frequencies of 160 MHz or greater:
  •     User Map 2, set register 0xF0 to 0x20;
  •     User Map 2, set register 0xF1 to 0x0F;
  •     User Map 2, set register 0xF4 to 0x70.
3) So we have the following questions:
    a. Because ADI don't give any more description about the 0xF0, 0xF1 and 0xF4 register, we are not sure our manual adjust can solve
        the issue in all our boards;
    b.What's  meaning of the register 0xF0, 0xF1 and0xF4? Is it similiar with the EQ_DYNx_LF/EQ_DYNx_HF of  ADV7842/ADV7623?
