HMC832
Question asked by YYHH on Jan 12, 2016
Latest reply on Jan 15, 2016 by dyoung1
Hi everyone,
I have some problems to programm the HMC832 PLL+VCO properly
I used the Evaluation software to test my configuration, and It seems all fine as I can get an output at the correct frequency loading this file:
REVISION 1.0.1.0
REG 1 2
REG 2 1
REG 3 1D
REG 5 FF88
REG 5 710
REG 5 4F98
REG 5 64A0
REG 5 5528
REG 5 7FB0
REG 5 4C38
REG 5 0
REG 6 F4A
REG 7 24CD
REG 8 C1BEFF
REG 9 5F7264
REG A 2046
REG B F8061
REG C 23
REG F 1
REG 10 20
REG 4 41D41E
XTAL 70
VCO_TO_SYNTH_DIV 1
VCO_TO_OUT_DIV 14
Nonetheless, when programming the chip from my FPGA with the same register values, I can not get an output signal from the chip. (The programming procedure is ok because I can get test signals from SDO pin).
It seems the chip is sensitive to the order registers are programmed.
Is there a special sequence to respect?
Thanks.
