Gnuradio blocks/drivers for CentOS
Question asked by andy_f on Jan 8, 2016
Latest reply on Jan 8, 2016 by andy_f
Hi, I'm trying to set up the gnuradio blocks on CentOS 7.
Following the steps located at What is libiio? [Analog Devices Wiki]
I am able to setup build and install libiio.
Then I can build, and install the AD9361 drivers from analogdevicesinc/libad9361-iio · GitHub.
However when I go through the cmake + build + install process to install the gnuradio blocks
It fails with the following errors:
-- checking for module 'libiio'
--   package 'libiio' not found
CMake Error at /usr/share/cmake/Modules/FindPkgConfig.cmake:279 (message):
  A required package was not found
Call Stack (most recent call first):
  /usr/share/cmake/Modules/FindPkgConfig.cmake:333 (_pkg_check_modules_internal)
  CMakeLists.txt:106 (pkg_check_modules)
-- checking for module 'libad9361'
--   package 'libad9361' not found
  CMakeLists.txt:108 (pkg_check_modules)
It seems to me that after installing the lines in the gnuradio/CMakeLists.txt
lines 105/106 can't locate the package configs
105 -- pkg_check_modules(IIO REQUIRED libiio)
106 -- pkg_check_modules(AD9361 REQUIRED libad9361)
but when I do
$ locate libiio.pc
/usr/lib/pkgconfig/libiio.pc
$ locate libad9361.pc
/usr/local/lib/pkgconfig/libad9361.pc
They are definitely there.
Do you know where pkg_check_modules looks?
Any help would be much appreciated
--Andy
