ADV7611 output data not in sync incoming data
Question asked by Anil@Ren on Jan 8, 2016
Latest reply on Jan 18, 2016 by GuenterL
We are generating a stable picture output and then sending it via HDMI output (TFP410PAP chip). When this is connected to a Monitor, we can observe the picture as intended. The resolution is 640x480@60p
Now using the above reference picture, we input this to ADV7611 chip. We expect ADV7611 to decode the incoming data and output it. Unfortunately, we observe that HYSNC, VSYNC, DE & LLC seem to be correct. But the Data is constantly changing. This implies that some how the incoming Data is not in sync with the outgoing data.
Attached are my setting
0x98, 0xFF, 0x80, //; I2C reset
0x98, 0xF4, 0x80, //; CEC
0x98, 0xF5, 0x7C, //; INFOFRAME
0x98, 0xF8, 0x4C, //; DPLL
0x98, 0xF9, 0x64, //; KSV
0x98, 0xFA, 0x6C, //; EDID
0x98, 0xFB, 0x68, //; HDMI
0x98, 0xFD, 0x44, //; CP
0x98, 0x01, 0x06, //; Prim_Mode =110b HDMI-GR
0x98, 0x02, 0xF2, //; Auto CSC, RGB out, dis op_656 bit
0x98, 0x03, 0x40, //; 24 bit SDR 444 Mode 0
0x98, 0x05, 0x28, //; AV Codes Off
0x98, 0x0B, 0x44, //; Power up part
0x98, 0x0C, 0x42, //; Power up part
0x98, 0x14, 0x7F, //; Max Drive Strength
0x98, 0x15, 0x80, //; Disable Tristate of Pins
0x98, 0x19, 0x83, //; LLC DLL phase
0x98, 0x33, 0x40, //; LLC DLL enable
0x44, 0xBA, 0x01, //; Set HDMI FreeRun
0x64, 0x40, 0x81, //; Disable HDCP 1.1 features
0x68, 0x9B, 0x03, //; ADI recommended setting
0x68, 0xC1, 0x01, //; ADI recommended setting
0x68, 0xC2, 0x01, //; ADI recommended setting
0x68, 0xC3, 0x01, //; ADI recommended setting
0x68, 0xC4, 0x01, //; ADI recommended setting
0x68, 0xC5, 0x01, //; ADI recommended setting
0x68, 0xC6, 0x01, //; ADI recommended setting
0x68, 0xC7, 0x01, //; ADI recommended setting
0x68, 0xC8, 0x01, //; ADI recommended setting
0x68, 0xC9, 0x01, //; ADI recommended setting
0x68, 0xCA, 0x01, //; ADI recommended setting
0x68, 0xCB, 0x01, //; ADI recommended setting
0x68, 0xCC, 0x01, //; ADI recommended setting
0x68, 0x00, 0x00, //; Set HDMI Input Port A
0x68, 0x83, 0xFE, //; Enable clock terminator for port A
0x68, 0x6F, 0x0C, //; ADI recommended setting
0x68, 0x85, 0x1F, //; ADI recommended setting
0x68, 0x87, 0x70, //; ADI recommended setting
0x68, 0x8D, 0x04, //; LFG
0x68, 0x8E, 0x1E, //; HFG
0x68, 0x1A, 0x8A, //; unmute audio
0x68, 0x57, 0xDA, //; ADI recommended setting
0x68, 0x58, 0x01, //; ADI recommended setting
0x68, 0x03, 0x98, //; DIS_I2C_ZERO_COMPR
0x68, 0x75, 0x10, //; DDC drive strength
For Debugging, i used the following information
I looked into the following and everything seems to be in line to my expectations:
0x98, 0x00, 0x08, // VGA 640x680@60
0x98, 0x01, 0x06, // HDMI-GR, 60Hz
0x68, 0x04, 0x23, // TMDS_PLL is locked to TDMS clock input
0x68, 0x05, 0x50, // HDMI Mode detected
0x68, 0x07, 0xA2, // Vertical filter locked, DE regeneration locked to incoming DE
0x68, 0x08,  0x80 // LineWidth 640
0x68, 0x09,  0x01 //
0x68, 0x0A, 0xE0 // Field0_Height 480
0x68, 0x0B, 0x01 // Progressive Input
0x68, 0x1C, 0x03 // FIFO has some margin, Video FIFO is not locked. Can this be some issue? How to solve this?
Any pointers into these issues would be great.
Anil
