(ADA4851-x)Power supply operating range.
Question asked by donadona999s on Jan 6, 2016
Latest reply on Jan 12, 2016 by donadona999s
Hi !
I have a question about the ADA4851-x's datasheet.
For example Table.1 t Page4 , it says "SPECIFICATIONS WITH +3V SUPPLY" ,
but at the Table.1 it says Operation Range is 2.7V to 12V.
And also the datasheet is written by each supply(+3V,+5V,±5V) but all of the table says
operation range is 2.7V to 12V.
If the operation range is always same , I think there is no reason to separate the table.
But at the datasheet, some of the electrical characteristic is different between the each supply power
so I think the datasheet should say
...for example...
  +3V => 2.7min~3.0typ~3.3max operation range
  +5V => 4min~5.0typ~6max operation range
  ±5V => ±4min~±5.0typ~±6max operation range
kind of this.
So my question is , Is it really 2.7~12V operation range in each supply voltage?
And if this is not correct , can you tell me each min & max supply voltage?
  => for example    2.7~3~3.3 @ +3 SUPPLY
Best regards.
Kawa
