AD9517-3 lock issue
Question asked by smutha on Jan 5, 2016
Latest reply on Jan 14, 2016 by smutha
         The problem is that the PLL is not locked and the output freq is not correct.
We have a 200MHz differential reference in and the loop filter is same as that on the eval board.
Reset is pulled high and Ref_Sel is tied low.
After writing all the registers once 0x018(0) is set to 1.
Then 0x01F is read and the result is 0x0E (VCO cal not done and no lock).
CP out pin is at 0V and bypass pin cap is at ~2.6V.
Thank you for your help,
The register settings are as follows: (For 125MHz CMOS out on o/p5)
AD9516/17/18 Register Map File, Rev 1.0
Addr(Hex)     Value(Bin)    Value(Hex)
0000          00011000      18
0001          00000000      00
0002          00010000      10
0003          01010011      53
0004          00000000      00
0010          01111100      7C
0011          11001000      C8
0012          00000000      00
0013          00000000      00
0014          01111101      7D
0015          00000000      00
0016          00000101      05
0017          00000000      00
0018          00000110      06
0019          00000000      00
001A          00000000      00
001B          00000000      00
001C          01000000      87
001D          00000000      00
001E          00000000      00
001F          00001110      0E
00A0          00000001      01
00A1          00000000      00
00A2          00000000      00
00A3          00000001      01
00A4          00000000      00
00A5          00000000      00
00A6          00000001      01
00A7          00000000      00
00A8          00000000      00
00A9          00000001      01
00AA          00000000      00
00AB          00000000      00
00F0          00001010      0A
00F1          00001010      0A
00F2          00001000      08
00F3          00001010      0A
00F4          00001010      0A
00F5          00001010      0A
0140          01000011      43
0141          01011010      5A
0142          01000011      43
0143          01000011      43
0190          00000000      00
0191          10000000      80
0192          00000000      00
0193          10111011      BB
0194          00000000      00
0195          00000000      00
0196          00000000      00
0197          00000000      00
0198          00000000      00
0199          00000000      00
019A          00000000      00
019B          00000000      00
019C          00000000      00
019D          00000000      00
019E          00100010      22
019F          00000000      00
01A0          00010001      11
01A1          00000000      00
01A2          00000000      00
01A3          00000000      00
01E0          00000010      02
01E1          00000010      02
0230          00000000      00
0231          00000000      00
0232          00000000      00
