ADV7391 - I2C ALSB Address Problems?
Question asked by ShaharW on Dec 28, 2015
Latest reply on Dec 31, 2015 by ShaharW
I'm using ADV7391 In my work design as a Bar Generator for some Video System. i'm having some communication problems while I2c conversation.
I'm using board TS4710 Linux arc.
application diagram:
VAA = 3.3V
VDD-IO = 3.3V
PVDD = 1.8V
VDD = 1.8V
COMP = -> 2.2nf -> 3.3V
RSET = -> 510ohm -> GND
EXT_LF = filter circuit (as the DATA SHEET)
ALSB = GND
CLKIN = 27Mhz Clock
NOT(RESET) = Normaly High (Active low)
P0-7 = -> 10kohm -> GND
V/HSYNC = ->10kohm -> 3.3V
SDA/SCL = TS4710 (I2c Port)
SFL = N.C
1) When i'm Power up there is some video signal in DAC1 output (default video settings - image DAC1 attach file)
2 i'm detecting I2c address in port 0x57 (despite Alsb=0)
3) After reseting the component, trying to send some subaddress commands ( i2cset -y 1 0x57 0x00 0x00)
according to the data sheet the conversation is fine (getting ACK) but the component dosen't react to the commands (still default video signal dispite 0x00 0x00 its a sleep mode).
4) I'm using more then the ADV7391 I2c component on the bus and they are working properly.
what the problem can be? is the component demaged?
thanks,
Shahar
