ADV7842 have problems in HDMI 1080p60 mode
Question asked by MartinGo on Dec 16, 2015
Latest reply on Dec 17, 2015 by Poornima
     I'm using ADV7842 as a HDMI receiver.Everything is ok when video resolution is 720p60:
     But when video resolution changes into 1080p60,we get this:
     Here is my configuration of ADV7842:
40 F1 90 ; SDP map
40 F2 94 ; SDPIO map
40 F3 84 ; AVLINK
40 F4 80 ; CEC
40 F5 7C ; INFOFRAME
40 F8 4C ; AFE
40 F9 64 ; KSV
40 FA 6C ; EDID
40 FB 68 ; HDMI
40 FD 44 ; CP
40 FE 48 ; VDP
40 00 02 ; Vid_Std =10b
40 01 06 ; Prim_Mode =110b HDMI-GR
40 02 F6 ; Auto input color space, Limited Range RGB Output
40 03 40 ; 24 bit SDR 444 Mode 0
40 05 28 ; AV Codes Off
40 06 A0 ; VS,HS Polarity
68 C1 FF ; HDMI power control (power saving)
68 C2 FF ; HDMI power control (power saving)
68 C3 FF ; HDMI power control (power saving)
68 C4 FF ; HDMI power control (power saving)
68 C5 00 ; HDMI power control (power saving)
68 C6 00 ; HDMI power control (power saving)
68 C0 FF ; HDMI power control (power saving)
40 0C 40 ; Power up part and power down VDP
40 15 80 ; Disable Tristate of Pins
40 19 83 ; LLC DLL phase
40 33 40 ; LLC DLL enable
44 BA 01 ; Set HDMI FreeRun
44 3E 00 ; Disable CP Pregain Block
44 6C 00 ; Use fixed clamp values
4C 00 FF ; Power Down ADC's and there associated clocks
4C 01 FE ; Power down ref buffer_bandgap_clamps_sync strippers_input mux_output buffer
4C B5 01 ; Setting MCLK to 256Fs
68 00 32 ; Set HDMI Input Port A (Enable BG monitoring)
68 01 18 ; Enable clock terminators
68 0D 34 ; ADI recommended write
68 1A 8A ; Unmute audio
68 3D 10 ; HDMI ADI recommended write
68 44 85 ; TMDS PLL Optimization
68 46 1F ; ADI Recommended Write ES3/Final silicon
68 60 88 ; TMDS PLL Optimization
68 61 88 ; TMDS PLL Optimization
68 6C 18 ; Disable ISRC clearing bit, Improve robustness
68 57 B6 ; TMDS PLL Optimization
68 58 03 ; TMDS PLL Setting
68 67 20 ; TMDS PLL Setting
68 75 10 ; DDC drive strength
68 85 1F ; ADI Equaliser Setting
68 87 70 ; HDMI Recommended write
68 89 04 ; ADI Equaliser Setting
68 8A 1E ; ADI Equaliser Setting
68 93 04 ; ADI Equaliser Setting
68 94 1E ; ADI Equaliser Setting
68 9D 02 ; ADI Equaliser Setting
68 99 A1 ; HDMI ADI recommended write
68 9B 09 ; HDMI ADI recommended write
68 C9 01 ; HDMI free Run based on PRIM_MODE, VID _STD
     By the way:
     I'm NOT using the ADV7842 evaluation board.
     My monitor'resolution is 1080p.
     My video source is a set top box.
     Samething happens when i use ADV7842 as a DVI receiver.
Martin
