How to make ADV7619 work  properly(HDMI PC)?
Question asked by gubuyu on Dec 14, 2015
Latest reply on Dec 16, 2015 by JeyasudhaMuthuPerumal
I'm using the ADV7619 (port A) to receive 1080p@60 video (4:4:4 RGB ,24bit,video from PC ).And I use the configuration below:
I have  got 2  problems:
1.In line 3,if I use address 0x7C, the ADV7619 does not work.but if I use address 0x7C ,the device works.  However, according to datasheet of “ADV7619 Reference Manual(Register Settings Recommendations)”,Infoframe Map Address is set to 0x7C. Which one is the correct slave address?
2.When the device works ,some pixels of  image flash. Image has  flash points !
How to make device work well ? Please give me some  useful advice to solve the problems. Thank You!
:02-06 720p,1080i,1080p In - 24-bit RGB 444 Out:
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
68 C0 03 ; ADI Required Write
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F7 ; Auto CSC, RGB out, Set op_656 bit
98 03 40 ; 24 bit SDR 444 Mode 0
98 05 28 ; AV Codes Off
98 06 A6 ; Invert VS,HS pins
98 0C 42 ; Power up part
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL MUX enable
44 BA 01 ; Set HDMI FreeRun
44 6C 00 ; Required ADI write
64 40 81 ; Disable HDCP 1.1 features
4C B5 01 ; Setting MCLK to 256Fs
68 C0 03 ; ADI Required write
68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
68 02 03 ; ALL BG Ports enabled
68 03 98 ; ADI Required Write
68 10 A5 ; ADI Required Write
68 1B 08 ; ADI Required Write
68 45 04 ; ADI Required Write
68 97 C0 ; ADI Required Write
68 3D 10 ; ADI Required Write
68 3E 69 ; ADI Required Write
68 3F 46 ; ADI Required Write
68 4E FE ; ADI Required Write
68 4F 08 ; ADI Required Write
68 50 00 ; ADI Required Write
68 57 A3 ; ADI Required Write
68 58 07 ; ADI Required Write
68 6F 08 ; ADI Required Write
68 83 FC ; Enable clock terminators for port A & B
68 84 03 ; ADI Required Write
68 85 11 ; ADI Required Write
68 86 9B ; ADI Required Write
68 89 03 ; ADI Required Write
68 9B 03 ; ADI Required Write
68 93 03 ; ADI Required Write
68 5A 80 ; ADI Required Write
68 9C 80 ; ADI Required Write
68 9C C0 ; ADI Required Write
68 9C 00 ; ADI Required Write
