iio_buffer_refill return -22 & -5
Question asked by jcsistemas2001 on Dec 12, 2015
Latest reply on Dec 13, 2015 by jcsistemas2001
I'm using the libiio to acquire data from a SPI device @1KHz. I just wondering if somebody could give a suggestion about it.
The application fail at:
ret = iio_buffer_refill(buffer);
The function return -22 or -5 as bellow:
Call to trigger_handler(int irq, void *p) at SPI IIO Device driver
Driver: Call to trigger_handler(int irq, void *p) at SPI IIO Device driver
Application: ret = -22, error = Invalid argument
Application: ret = -5, error = Input/output error
Driver:Call to trigger_handler(int irq, void *p) at SPI IIO Device driver
Application:ret = -22, error = Invalid argument
Application:ret = -5, error = Input/output error
I already report this issue at linux-iio list. I paste the same message here as reference (Gmane -- read  dev iio:device0 return  1  Invalid argument):
I get an error trying to read /dev/iio:device0 in a custom application
(C/C++), however in a terminal the command "cat /dev/iio_device0"
return data.
Below the procedure:
- enable channels
- setup trigger
- setup buffer lenght
- enable buffer (the SPI interrupt is setup properly and all the
trigger handler are done)
- read /dev/iio_device0
It's a SPI device acquiring 27 bytes <at> 1KHz.
Results:
1. Custom application (based on generic_buffer.c): function 'read'
return -1 and strerror(errno) return "Invalid argument"
2. iio_readdev (libiio): show the message "Unable to refill buffer:
Input/output error"
3. In terminal, the command "cat /dev/iio_device0" show values (no
readable) while the buffer is enable.
