ADV7441 DVI input color problem
Question asked by Bhavyak on Dec 11, 2015
Latest reply on Dec 23, 2015 by mattp
I am using ADV7441 HDMI receiver interface which takes DVI input and gives out 24bit RGB output. The RGB output is just bypassed to the DVI output in the FPGA. At the output display we are seeing change in some colors. The blue color input changes to purple color and black changes to red. The other color components are also not very clean. Following are my register settings, I am setting the RGB output with automatic CSC and the CP_OP mode I am setting is mode 13 as per hardware datasheet. Is there any other setting that Im missing for this color problem to be solved.
   // CTS THRESHOLD is set to 0x1F
    i2c_write(base,0x6A>>1,0x10,0x1F);
    // Recommended Setting for Bcaps Register Bit 1
    red_res = i2c_read(base,0x66>>1,0x40);
    value = (red_res & 0xFD);
    i2c_write(base,0x66>>1,0x40,value);
  // Recommended Setting for Bcaps Register Bit 7 for DVI
     i2c_write(base,0x66>>1,0x40,0x0);
     i2c_write(base,0x42>>1,0x03,0x0C) ; //Disable TOD
     i2c_write(base,0x42>>1,0x05,0x06) ; //Prim_Mode =0110b HDMI
     i2c_write(base,0x42>>1,0x1D,0x40) ; //Disable TRI_LLC
     i2c_write(base,0x42>>1,0x37,0x00) ; //Disable PCLK
     i2c_write(base,0x42>>1,0x6B,0xEE); // Enable DE, CP_OP= 14 (mode 13)
     i2c_write(base,0x42>>1,0x68,0xF2) ; //Auto CSC , RGB Out
     i2c_write(base,0x42>>1,0xBA,0xA0) ; //Enable HDMI and Analog in
     i2c_write(base,0x42>>1,0xC8,0x08) ; //Digital Fine Clamp Start position
     i2c_write(base,0x42>>1,0x7B,0x0D) ; //Disable AV code Insertion
     i2c_write(base,0x42>>1,0x7C,0x0F) ; //Positive Output Sync Polarity
     i2c_write(base,0x42>>1,0x7D,0xFF) ; //
     i2c_write(base,0x42>>1,0x7E,0xFF) ; //
     i2c_write(base,0x42>>1,0xF4,0x3F) ; //Max Drive Strength
     i2c_write(base,0x62>>1,0xF0,0x10) ; //ADI Recommended Write
     i2c_write(base,0x62>>1,0xF1,0x0F) ; //ADI Recommended Write
     i2c_write(base,0x62>>1,0xF4,0x20) ; //ADI Recommended Write
     i2c_write(base,0x6A>>1,0x15,0xEC) ; //Disable these mute mask bits
     i2c_write(base,0x6A>>1,0x1C,0x49) ; //Set MCLKOUT to output 256fs
     i2c_write(base,0x6A>>1,0x1D,0x04) ; // & Set Unmute Delay to 1_5 sec.
     i2c_write(base,0x6A>>1,0x5A,0x01) ; //Reset Audio Pll
