Scripting for FMCOMMS5 MCS
Question asked by rmd91 on Dec 11, 2015
Latest reply on Dec 14, 2015 by rmd91
I've been able to get my design working using the IIO Oscilloscope and Linux drivers, but my project will ultimately need to run without having a person controlling the GUI. We've been able to set parameters like RX and TX sampling rate, but noticed that the receive waveforms will often be distorted. Initially, we were clicking "Reload Settings" and the problem would go away. If our script is run more than once, this fix doesn't work.
After some debugging, I found that pressing the MCS Sync button fixes this problem. I believe this is because MCS must be run after changing the sampling rate. How can I integrate MCS into the script I've included below? I've tried echo 2 > multichip_sync as I saw in another forum post but that didn't work. I've only been able to get it working through the GUI. If it isn't possible with this method, could you direct me to the solution using libiio in C?
FCRX1_DEFAULT=739000000
FCTX1_DEFAULT=739000000
FCRX2_DEFAULT=739000000
FCTX2_DEFAULT=739000000
FS=15360000
if [ "$#" -eq "4" ]
then
    FCRX1=$1
    FCTX1=$2
    FCRX2=$3
    FCRX2=$4
else
    FCRX1=$FCRX1_DEFAULT
    FCTX1=$FCTX1_DEFAULT
    FCRX2=$FCRX2_DEFAULT
    FCTX2=$FCTX2_DEFAULT
fi
BW=10000000
echo "Frequency Translation Demo"
echo "RX1 Frequency: $FCRX1 Hz"
echo "TX1 Frequency: $FCTX1 Hz"
echo "RX2 Frequency: $FCRX2 Hz"
echo "TX2 Frequency: $FCTX2 Hz"
PHYA_PATH=/sys/bus/iio/devices/iio\:device1
PHYB_PATH=/sys/bus/iio/devices/iio\:device2
TX1_PATH=/sys/bus/iio/devices/iio\:device4
RX1_PATH=/sys/bus/iio/devices/iio\:device6
TX2_PATH=/sys/bus/iio/devices/iio\:device5
RX2_PATH=/sys/bus/iio/devices/iio\:device7
#echo 0 > $TX1_PATH/out_altvoltage0_TX1_I_F1_raw
# Setup phy
echo $FS > $PHYA_PATH/in_voltage_sampling_frequency
echo $FS > $PHYA_PATH/out_voltage_sampling_frequency
echo $BW > $PHYA_PATH/in_voltage_rf_bandwidth
echo $BW > $PHYA_PATH/out_voltage_rf_bandwidth
echo $FCRX1 > $PHYA_PATH/out_altvoltage0_RX_LO_frequency
echo $FCTX1 > $PHYA_PATH/out_altvoltage1_TX_LO_frequency
echo $FS > $PHYB_PATH/in_voltage_sampling_frequency
echo $FS > $PHYB_PATH/out_voltage_sampling_frequency
echo $BW > $PHYB_PATH/in_voltage_rf_bandwidth
echo $BW > $PHYB_PATH/out_voltage_rf_bandwidth
echo $FCRX2 > $PHYB_PATH/out_altvoltage0_RX_LO_frequency
echo $FCTX2 > $PHYB_PATH/out_altvoltage1_TX_LO_frequency
# Setup TX
echo 0 > $TX1_PATH/buffer/enable
#echo 0 > $TX2_PATH/buffer/enable
#for i in {0..3}
#do
#    echo 1 > $TX_PATH/scan_elements/out_voltage${i}_en
#done
echo 1 > $TX1_PATH/scan_elements/out_voltage0_en
echo 1 > $TX1_PATH/scan_elements/out_voltage1_en
echo 1 > $TX1_PATH/scan_elements/out_voltage2_en
echo 1 > $TX1_PATH/scan_elements/out_voltage3_en
echo 1 > $TX1_PATH/scan_elements/out_voltage4_en
echo 1 > $TX1_PATH/scan_elements/out_voltage5_en
echo 1 > $TX1_PATH/scan_elements/out_voltage6_en
echo 1 > $TX1_PATH/scan_elements/out_voltage7_en
echo 1 > $TX1_PATH/buffer/enable
# Setup RX
echo 0 > $RX1_PATH/buffer/enable
#for i in {0..3}
#do
#    echo 1 > $RX_PATH/scan_elements/in_voltage${i}_en
#done
echo 1 > $RX1_PATH/scan_elements/in_voltage0_en
echo 1 > $RX1_PATH/scan_elements/in_voltage1_en
echo 1 > $RX1_PATH/scan_elements/in_voltage2_en
echo 1 > $RX1_PATH/scan_elements/in_voltage3_en
echo 1 > $RX1_PATH/scan_elements/in_voltage4_en
echo 1 > $RX1_PATH/scan_elements/in_voltage5_en
echo 1 > $RX1_PATH/scan_elements/in_voltage6_en
echo 1 > $RX1_PATH/scan_elements/in_voltage7_en
echo 1 > $RX1_PATH/buffer/enable
#./set_bypass_fmcomms5 1
