Connect adau1701 to Linux Processor
Question asked by Krzyzanowski on Dec 8, 2015
Latest reply on Dec 11, 2015 by DaveThib
I am facing issue with getting any response from adau1701.
I would like to use I2S port and ALSA to stream music.
But at the begging I have to be able to communicate with ADAU1701. As far as I understand it correctly steps needed:
1. Enable all supplies
2. Enable MCLK
3. Reset (rising edge needed)
4. Set configuration through I2C
5. Communicate via I2S.
1. --> So I enable all supplies needed and check with oscilloscope - OK.
2. --> I enable MCLK (26MHz with existing Linux driver, but also checked with external function generator (sinus 11.289MHz both 1.8V and 3.3V))
3. --> And I am preforming reset:
echo 0 > /sys/class/gpio/gpioX/value
sleep 5
echo 1 > /sys/class/gpio/gpioX/value
4. --> Nothing. I can't get any response from ADAU1701. I check with I2C tools:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- UU -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- 62 -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
And should get response between 68-6F. (Those 62 and 70 are different device on same bus to check if I2C communication works). I can see that power consume by board rising if I enable clock and have reset high.
System: Linux 3.0.35
