ADuC7024 Wake-up timer
Question asked by Zeal on Dec 7, 2015
Latest reply on Dec 17, 2015 by Zeal
Hello, has anyone used the wake-up timer to bring a nap mode ADuC7024 back to its active mode?My testing codes are like below. When I comment out the line “PLL_OSC_CON_EnterPowerMode(OPERATING_MODE_NAP_MODE);”, My LED blinks correctly. However, the LED just keeps ON after it enters the NAP mode and it seems the wake-up timer has stopped working.
#define MMR_BASE                                                        ((uint32_t)0xFFFF0000)
#define PLL_AND_OSCILLATOR_CONTROL_BASE         (MMR_BASE + 0x0404)
typedef struct{
     __W uint16_t POWKEY1;
     uint8_t Reserved0[2];
     __RW uint16_t POWCON;
     uint8_t Reserved1[2];
     __W uint16_t POWKEY2;
     uint8_t Reserved2[2];
     __W uint16_t PLLKEY1;
     uint8_t Reserved3[2];
     __RW uint8_t PLLCON;
     uint8_t Reserved4[3];
     __W uint16_t PLLKEY2;
} PLL_OSC_CON_TypeDef;
#define PLL_OSC_CON                 (*(PLL_OSC_CON_TypeDef*) PLL_AND_OSCILLATOR_CONTROL_BASE)
typedef enum{
  OPERATING_MODE_ACTIVE_MODE = 0x0000,
  OPERATING_MODE_PAUSE_MODE = 0x0010,
  OPERATING_MODE_NAP_MODE = 0x0020,
  OPERATING_MODE_SLEEP_MODE = 0x0030,
  OPERATING_MODE_STOP_MODE = 0x0040
} PC_TypeDef;
void PLL_OSC_CON_EnterPowerMode(PC_TypeDef mode){
     PLL_OSC_CON.POWKEY1 = 0x01;
     PLL_OSC_CON.POWCON = mode;
     PLL_OSC_CON.POWKEY2 = 0xF4;
void main() {
     Timer2_INIT_TypeDef Timer2_InitSetting;
     LED_INIT();
     LED_On();
     Timer2_InitSetting.Precale = TIMER1_2_PRESCALER_32768;
     Timer2_InitSetting.Format = TIMER1_2_FORMAT_BINARY;
     Timer2_InitSetting.Mode = TIMER_MODE_PERIODIC;
     Timer2_InitSetting.Count_Direction = TIMER1_2_3_COUNT_DOWN;
     Timer2_InitSetting.Source = Timer2_Clock_Source_HCLK;
     Timer2_InitSetting.Load_Value = 1275;
     Timer2_Init(&Timer2_InitSetting);
     IRQ_CON_EnableIRQ(IRQ_WAKE_UP_TIMER);
     Timer2_EnableControl(TIMER_ENABLE);
     while(1);
__irq void IRQ_Handler () {
     static uint32_t t = 0;
     if(IRQ_CON.IRQSTA.b.Wake_Up_Timer == 1){
          TIMER2.CLRI = 0x1;
          if(t++%2)          LED_On();
          else                 LED_Off();
I will be very appreciated if anyone could help. Thanks.
