ADV7619 4K variable line width
Question asked by lio on Nov 25, 2015
Latest reply on Feb 5, 2016 by JeyasudhaMuthuPerumal
I have got some issue when receiving a 4096x2160p@24Hz signal.
The data enable we receive must be 2048T long per line, but sometimes, the received DE signal is not that length. (I checked that using an internal counter in our FPGA in the video clock domain)
The result frame is jittering and looks like the attached file.
Sometimes it's working correctly, depending on the start condition (??) but most of the time, it's not.
I also tried different phases for the LLC output.
The size of the qualifier could be +1 with several phases, but most of the time, it's -1.
But none of them, give us a correct result. I mean, it fails at least one time for each phase.
The configuration script I used is : ADV7619-VER.1.4c.txt
## 4kx2k out through DAC ##
:4kx2k 444 lower part of bus:
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
68 C0 03 ; ADI Recommended Write
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F2 ; Auto CSC, RGB out, Set op_656 bit
98 03 54 ; 2x24 bit SDR 444 interleaved mode 0
98 05 28 ; AV Codes Off
98 06 A0 ; No inversion on VS,HS pins
98 0C 42 ; Power up part
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL MUX enable
98 DD A0 ; LLC Half frequency
4C B5 01 ; Setting MCLK to 256Fs
4C C3 80 ; ADI recommended writes (HiFreq)
4C CF 03 ; ADI recommended writes (HiFreq)
68 C0 03 ; ADI Required write
68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
68 02 03 ; ALL BG Ports enabled
68 03 98 ; ADI Required Write
68 10 A5 ; ADI Required Write
68 45 04 ; ADI Required Write
68 97 C0 ; ADI Required Write
68 3D 10 ; ADI Required Write
68 3E 69 ; ADI reccommended writes
68 3F 46 ; ADI reccommended writes
68 4E FE ; ADI reccommended writes
68 4F 08 ; ADI reccommended writes
68 50 00 ; ADI Recommended Write
68 57 A3 ; ADI reccommended writes
68 58 07 ; ADI reccommended writes
68 83 FC ; Enable clock terminators for port A & B
68 84 03 ; FP MODE
68 85 10 ; ADI recommended setting
68 86 9B ; ADI recommended setting
68 89 03 ; HF Gain
68 9B 03 ; ADI recommended setting
68 93 03 ; ADI recommended setting
68 5A 80 ; ADI recommended setting
End
Thanks for your help,
Lionel
