ADXL362 FIFO watermark interrupt configuration
Question asked by rathinasamyks on Nov 25, 2015
Latest reply on Jan 5, 2016 by NevadaMark
Hello All,
I am trying to connect ADXL362 with CC2650 for my application.
My objective is to set the watermark interrupt for complete FIFO depth (1020 bytes only XYZ values)
configuration :
1. SPI open (4 MHz)
2. ADXL362 initialization and SOFT RESET
3. Range :  8g
4.  Halved bandwidth of the filter : 1/2 the ODR
5. ODR : 400 Hz
6. FIFO set up  - >
     -  ADXL362_REG_FIFO_CONTROL(0x28) -: 0x0A
    -  ADXL362_REG_FIFO_SAMPLES(0x29) : 0xFF - Assuming If if AH bit is set in ADXL362_REG_FIFO_CONTROL(0x28) then
      configured FIFO depth is 511 samples (1024 bytes : ~170 * 3 * 2)
7. Set FIFO watermark interrupt
     - ADXL362_REG_INTMAP1(0x2A) : 0x84 : ( Active low | Watermark interrupt)
8. Set measurement mode
    -  ADXL362_REG_POWER_CTL(0x2D) : 2
Expectation :
Upon sampling of 1020 bytes in FIFO an interrupt triggered .
Actual :
I am getting interrupt immediately once , I do step 7 then after that my system going to undefined state.
Is there any mistake in my ADXL362 configuration ?
Is my assumption is correct ? "Assuming If if AH bit is set in ADXL362_REG_FIFO_CONTROL(0x28) then configured FIFO depth is 511 samples (1024 bytes : ~170 * 3 * 2) "
