21469 EZ Board crashes on 16-bit SPIB Master Core Read....
Question asked by PatrickM on Jun 13, 2011
Latest reply on Jun 14, 2011 by jeyanthi.jegadeesan
I am using a 21469 EZ Board with some low latency DAC's and ADC's attached.  We are using the board to verify algorithms for a communication system.
A subset of the I/O pins on connector P2 are shown below.  All the switches shown in bold are OFF to allow the respective I/O signal to pass through to the attached board.
The SPI port drives several AD5663 2.7 V to 5.5 V, 250 ìA, Rail-to-Rail Output, Dual 16-Bit nanoDACs.  We select the appropriate DAC by setting FLAG0-3 bits (named MUX_CONTROL_X below).  This works quite well.  I've included the test code to output a sine wave using a timer interrupt.
The SPIB port drives anADIS16400 Triaxial Inertial Sensor with Magnetometer, hereinafter referred to as the IMU.  Using DMA I can read data from the IMU through SPIB.  However, when I try read a single sixteen bit value the processor crashes.  The error that I get from the debugger is "<empty_stack + 0x2e>.  I'm presuming that some sort of uninitialized trap instruction was invoked by the instruction which crashed the processer.
The crash occurs in the following subroutine at the line marked in BOLD.  As nearly as I can tell this is a perfectly legal statement....
// Read the ADIS16405 IMU...
int SpiBRead16( int address )
int input;
*pSPIDMACB = 0; // Disable SPIB DMA
*pSPICTLB = (TXFLSH | RXFLSH); // Flush TX and RX buffers
*pSPIBAUDB = 114; // Measured 1 MHz baud rate divider...
*pSPIFLGB = DS0EN; // CPHASE with AUTOSDS
*pSPICTLB =
  SPIMS |  // The processer is SPI master
  MSBF |   // Most Significant Bit First
  WL16 |   // Word length is 16-bits
  CPHASE |  // Start SPICLK at the beginning (rather than middle) of the first bit
  CLKPL |  // Active low SPI clock
  AUTOSDS; // Device select is controlled by SPI hardware
*pTXSPIB = address;
*pSPISTATB = 0xFF; // Clear any SPI errors
*pSPICTLB |= SPIEN; // Enable SPIB port
// A dummy read starts the SPI. Then we have to trasmit a dummy word
// to get the real data...
input = *pRXSPIB; // do a dummy read to allow the SPI to start
while ((*pSPISTATB & SPIF) == 0); // wait for transmission to complete
// Enable SPIB port
*pSPICTLB |= SPIEN;
*pTXSPIB = 0x0000;
// copy the SPI data into the raw data buffer
input = *pRXSPI;
*pSPICTL = 0; // disable
return input;
How can I tell what is causing the crash?  Is there available a canned set of interrupts which would indicate the source of the problem?  Am I using the SPIB Master Core Read functionality correctly?
Thanks in advance for your help,
Patrick Mealey
Sr. Software Engineer
AOptix
Pin
Name
Function
New Function
Description
Switch
24
DPI3
SPI_CLK
SPI_CLK
SPI Clock Signal
SW3.3
25
DPI1
SPI_MOSI
SPI_MOSI
SPI Master Out Slave In
SW3.1
26
DPI5
SPI_CS
SPI_CS
SPI Slave Device Select
SW3.5
27
DPI2
SPI_MISO
SPI_MISO
SPI Master In Slave Out
SW3.2
28
DPI6
LED1
LED1
LED 1
SW3.6
29
DPI8
TEMP_SCK
SPIB_CS
SPI B Slave Device Select
SW3.8
30
DPI7
TEMP_SDA
SPIB_MISO
SPI B Master In Slave Out
SW3.7
31
DPI9
UART_TX
UART_TX
UART Transmit
32
DPI10
UART_RX
UART_RX
UART Receive
33
DPI12
UART_CTS
SPIB_MOSI
SPI B Master Out Slave In
SW14.4
34
DPI11
UART_RTS
SPIB_CLK
SPI B Clock Signal
SW14.3
35
RESET
Reset
Reset
Reset Signal Output
36
NC
No Connection
No Connection
37
FLAG0
TEMP_THERM
MUX_CONTROL 1
MUX Control Line 1
SW13.3
38
FLAG1
PB1
MUX_CONTROL 2
MUX Control Line 2
SW13.4
39
FLAG2
PB2
MUX_CONTROL 3
MUX Control Line 3
SW13.5
