BF609 CAN Interface
Question asked by KAUSTUBH_IRDE on Nov 24, 2015
Latest reply on Dec 21, 2015 by KAUSTUBH_IRDE
hi all
i have configured CAN interface on BF609 processor. as per hardware reference manual it is looking ok, but it is not communicating. communication means, first i am trying only data transmit on CAN interface. configuration is like that after transmit, it should generate transmit interrupt.
but this is not working.
i have attached configuration code with CAN transmit and transmit interrupt service routine function.
bool Init_CANPort(int config)
    int i = 0,j = 0;
    unsigned int nTimer;
    short msgID;
    char mbID;
    volatile unsigned short *pCAN_Ptr;
    *pREG_SEC0_CPMSK0 = 0x30;
    *pREG_SEC0_SCTL0 = 0x00003005;
    // PortG MUX and FER registers are configured (PG4=CAN RX, PG1=CAN TX)
    /* PORTG_MUX = 0x0000 0208
       PORTG_FER = 0x0012
    *pREG_PORTG_MUX &= ~(BITM_PORT_MUX_MUX1 | BITM_PORT_MUX_MUX4);
    *pREG_PORTG_MUX |= ((( 2 << BITP_PORT_MUX_MUX1) & BITM_PORT_MUX_MUX1) | (( 2 << BITP_PORT_MUX_MUX4) & BITM_PORT_MUX_MUX4));
    *pREG_PORTG_FER_SET  =    ( BITM_PORT_FER_PX1 | BITM_PORT_FER_PX4 );
    ssync();
    // Initialize the CAN interrupts
    if(config & CAN_RX)
        adi_int_InstallHandler(INTR_CAN0_RX, (ADI_INT_HANDLER_PTR)CAN_RX_ISR, NULL, false);
    if(config & CAN_TX)
        adi_int_InstallHandler(INTR_CAN0_TX, (ADI_INT_HANDLER_PTR)CAN_TX_ISR, NULL, false);
    //adi_int_InstallHandler(INTR_CAN0_STAT, (ADI_INT_HANDLER_PTR)CAN_ERR_ISR, NULL, false);
    /* Initialize the CAN timing registers and can clock
    SCLK = 125MHZ, CAN Clock = 500kHz (so tBIT = 2us)
    CAN_CLOCK  : Prescaler (BRP)
    CAN_TIMING : SJW = 3, TSEG2 = 5, TSEG1 = 2
    *pREG_CAN0_TIMING = 0x0352;    // try 0x0325 // 0x352
    *pREG_CAN0_CLK  = 24;    // its value depends upon CANCLK and SCLK
    ssync();
    // Initialize the CAN mail boxes and turn on the can ISR.
    /* Mailboxes 16-31 are TX mailbox (Mailbox 16 Transmits ID 0x200) */
    msgID = 0x200;
    for (mbID = 16; mbID<32; mbID++)
        pCAN_Ptr = (unsigned short *)(pREG_CAN0_MB00_DATA0 + (0x10 * mbID));
        *(pCAN_Ptr + 0)  = msgID;         /* write msgID to DATA0 */
        *(pCAN_Ptr + 2)  = msgID;         /* write msgID to DATA1 */
        *(pCAN_Ptr + 4)  = msgID;         /* write msgID to DATA2 */
        *(pCAN_Ptr + 6)  = msgID;         /* write msgID to DATA3 */
        *(pCAN_Ptr + 8)  = 8;             /* write 8 to LENGTH */
        *(pCAN_Ptr + 10) = 0;             /* write 0 to TIMESTAMP */
        *(pCAN_Ptr + 12) = 0;             /* write 0 to ID0 */
        *(pCAN_Ptr + 14) = (msgID << 2);     /* write msgID to ID1.BASEID */
        msgID++;                /* Increment msgID for next mailbox */
    } /* end for (Initialize TX mailbox area) */
    /* Mailboxes 0-15 are RX mailbox (Mailbox 0 Receives ID 0x200) */
    msgID = 0x200;
    for (mbID = 0; mbID<16; mbID++)
        *(pCAN_Ptr + 0)  = 0;              /* write msgID to DATA0 */
        *(pCAN_Ptr + 2)  = 0;             /* write msgID to DATA1 */
        *(pCAN_Ptr + 4)  = 0;             /* write msgID to DATA2 */
        *(pCAN_Ptr + 6)  = 0;             /* write msgID to DATA3 */
        msgID ++;                /* Increment msgID for next mailbox */
    } /* end for (Initialize RX mailbox area) */
    /* enable the CAN and the mailboxes */
    *pREG_CAN0_MD1 = CAN_RX_MB_LO;        /* mailboxes 0-15 are configured as Receiver */
    *pREG_CAN0_MD2 = CAN_RX_MB_HI;        /* mailboxes 16-31 are configured as Transmitter */
    /* Enable All Mailboxes */
    *pREG_CAN0_MC1 = CAN_EN_MB_LO;         /* mailboxes 0-15 */
    *pREG_CAN0_MC2 = CAN_EN_MB_HI;         /* mailboxes 16-31 */
    ssync();
    // Enable CAN Configuration Mode (Clear CCR)
    /* Exit CAN Configuration, Suspend and sleep mode and then wait for CAN to exit all mode */
    *pREG_CAN0_CTL = 0;
    /* Wait for CAN Configuration Acknowledge (CCA) */
    for(i=0;i<65535;i++);
    do
        asm("nop;");
        for(j=0;j<65535;j++);
    }while(*pREG_CAN0_STAT & BITP_CAN_STAT_CCA);
    *pREG_CAN0_MBIM1 = CAN_EN_MB_LO;    /* Enable Interrupt for Mailboxes 0-15 */
    *pREG_CAN0_MBIM2 = CAN_EN_MB_HI;    /* Enable Interrupt for Mailboxes 16-31 */
    ssync();
    // Enable CAN Receive, CAN Transmit Interrupt
    if(config & CAN_RX)
        adi_int_EnableInt (INTR_CAN0_RX, true);
    if(config & CAN_TX)
        adi_int_EnableInt (INTR_CAN0_TX, true);
    //adi_int_EnableInt (INTR_CAN0_STAT, true);
    return true;
} /* End Init_Port () */
void CAN_TX_ISR(void)
    unsigned short mbint_status;
    unsigned short mask = 1;
    char mailbox = 0;
    mbint_status = *pREG_CAN0_MBTIF2;
    while(mbint_status != 0)
        if(mbint_status & mask)
            TX_CANPort.mbTx_Status[mailbox] = true;
            mbint_status &= ~mask;
            *pREG_CAN0_MBTIF2 = mask;    //w1c
            *pREG_CAN0_TA2    = mask;    //w1c
            //ssync();
        mask = mask << 1;
        mailbox++;
    }// while(mbint_status != 0)
    ssync();
    return;
void CANPort_Transmit(CAN_TxPORT *canPort)
    int mbID = 0, j = 0;
    mbID = canPort->baseMB;
    for(; mbID<32; mbID++)
        *(pCAN_Ptr + 6) = canPort->CAN_TxBuffer[j++];
        *(pCAN_Ptr + 4) = canPort->CAN_TxBuffer[j++];
        *(pCAN_Ptr + 2) = canPort->CAN_TxBuffer[j++];
        *(pCAN_Ptr + 0) = canPort->CAN_TxBuffer[j++];
    *pREG_CAN0_TRS1 = 0x0000;
    *pREG_CAN0_TRS2 = 0xFFFF;
    ssync();
    return;
