Output data rate 3200HZ?
Question asked by gandhi on Nov 18, 2015
Latest reply on Jan 6, 2016 by NevadaMark
Output data rate 3200HZ.. means that we could see the 3200 samples per second on serial terminal?
For my university project I'm working on ADXL345 with nucleo-L053 (ST controller). I always see same data rate about 350HZ on serial terminal at 115200 baud rate.
For 50HZ input (BW_Rate register = 0x09) the output at serial terminal is 50 variations but with 350 samples per second. Means one samples displayed for about 7 times.
For 100HZ input (BW_rate register = 0x0A),the output at serial terminal is with 100 variatons but with 350 samples per second. each sample almost dislyed 4 times. Is this normal? or?
I need high data rates for my project like 3200HZ and 1600HZ.. Can i able to see 3200 samples per second on serial terminal.
My serial terminal is showing maximum 650 samples per second at high baud rate like 921600.
Thank you.
