Creating STANAG B from RGBHV
Question asked by Arhez on Nov 16, 2015
Latest reply on Nov 17, 2015 by DaveD
Hello
I want to create STANAG B from RGBHV (coming from my PC).
I know that STANAG 3350 Class B means 625 Lines, 25 Frames/ Sec, 50 Fields/ Sec which is based on PAL.
After doing a little research I realized that if I encoded RGB to PAL I'd be doing the same thing.
I found AD725. It encodes RGBHV to PAL.
My questions are as following:
1. Am I on the right track with AD725? I am a little confused because I read somewhere that it requires interlaced RGBHV but in the datasheet it has "Personal Computers" listed in Applications.
2. Am I wrong when I say that converting RGBHV to PAL will be the same as converting to STANAG B? what is the characteristic that differs PAL from STANAG B? -In my research I found that it'll need scaling and that could be done using ADV8003.
3. If AD725 will work. Do I need to change anything in the output and then do the scaling ?
Help will be appreciated!
