BF 705 EZLite SD card identification problem
Question asked by wlodek on Nov 13, 2015
Latest reply on Jun 17, 2016 by wlodek
When running the sample Power_On_Self_test program for the BF707 the Test_SD test hangs in sd_mmc_identification_sdv2(uint32_t response) procedure.
The do .. while loop never ends.
do{   /* card with compatible voltage range */
        DEBUG_STATEMENT("\n   Requesting OCR register... ");
        error = sd_mmc_send_command(SD_MMC_CMD_APP_CMD, 0, RESPONSE_SHORT, TRANS_NONE, CRCDIS);
        adi_rsi_GetShortResponse(hDevice, &response);
       error = sd_mmc_send_command(SD_CMD_GET_OCR_VALUE, 0x40FF8000, RESPONSE_SHORT, TRANS_NONE, 0);
       DEBUG_STATEMENT("\n   OCR register received");
       adi_rsi_card_registers.sd.ocr = response;
    }while(!(adi_rsi_card_registers.sd.ocr & (unsigned int)SD_OCR_CARD_POWER_UP_STATUS));
This only happens when I use the SDHC cards with capacity higher than 2GB.
The same test on 2 GB card runs smoothly.
Can somebody help ?
