Trying to enable fir filter on ad9361 with zc702
Question asked by atg on Nov 11, 2015
Latest reply on Nov 11, 2015 by atg
I am trying to set the programmable FIR filter on the ad9361 using the Matlab app AD9361 Filter Design Wizard (MATLAB Filter Design Wizard for AD9361 [Analog Devices Wiki]). I have designed my filter, and loaded the coefficients as so:
root@analog:/sys/bus/iio/devices/iio:device1# filter_coeff.txt > filter_fir_config
When I try to enable the fir filter
echo 1 > in_voltage_filter_fir_en
I get the response: bash: echo: write error: Invalid argument
I assume this means there is something wrong with my coefficients, since I loaded the filter coefficients  here: ad9361 device driver trouble as a test, and they loaded fine with no error messages.
Since I used the matlab app, I assumed the coefficients I generated would be valid (or it would warn me) but maybe not. All I really want for my filter is for it to decimate the samples enough so that I can have a sampling rate of ~400ksps coming out of the ad9361, with a passband of ~150khz. I'm not too concerned about what the stop band should be. Below are the filter coefficients that the app generated:
# RX [1, 2, 3(both)] GAIN [-12 -6 0 6] DEC [1 2 4]
# TX [1, 2, 3(both)] GAIN [-6 0] INT [1 2 4]
RX 3 GAIN -12 DEC 4
28
-72
-9
-173
-159
-294
-271
-297
-179
-76
99
203
271
209
82
-116
-275
-358
-289
-103
164
391
496
400
128
-242
-557
-687
-538
-146
365
789
940
708
147
-555
-1114
-1277
-915
-115
847
1581
1742
1177
24
-1312
-2288
-2429
-1538
173
2115
3492
3604
2138
-620
-3795
-6127
-6357
-3665
1995
9785
18134
25151
29154
29154
25151
18134
9785
1995
-3665
-6357
-6127
-3795
-620
2138
3604
3492
2115
173
-1538
-2429
-2288
-1312
24
1177
1742
1581
847
-115
-915
-1277
-1114
-555
147
708
940
789
365
-146
-538
-687
-557
-242
128
400
496
391
164
-103
-289
-358
-275
-116
82
209
271
203
99
-76
-179
-297
-271
-294
-159
-173
-9
-72
28
Thank you!
