Receive external I2S, SPORT configuration
Question asked by klhett on Jun 8, 2011
Latest reply on Jun 17, 2011 by DeepV
I am trying to configure a 21489 ez-kit board to receive I2S from an external DAC.
I would like to use the I2S input as the clocking reference for the 1931 codec so I can send the received audio back off the board as an analog signal.
I think this should be possible because it seems very similar to the "SPDIF to analog talkthrough" example program.  The main difference is that the I2S data comes from the on-chip SPDIF receiver versus the external header pins.
The connections I have between the external DAC and the ez-kit board are:
(all connections are made on the P2 expansion header)
DAC_FS -> DAI_P15
DAC_BCLK -> DAI_P16
DAC_DATA -> DAI_P17
Here is my code for setting up the SRU:
I'm using SPORT1 as the receiver, as in the SPDIF to analog example code.
void InitDAI()
    clearDAIpins();
    SRU(DAI_PB15_O, SPORT1_FS_I);
    SRU(DAI_PB15_O, SPORT0_FS_I);
    SRU(DAI_PB15_O, SPORT2_FS_I);
    SRU(DAI_PB16_O, SPORT1_CLK_I);
    SRU(DAI_PB16_O, SPORT0_CLK_I);
    SRU(DAI_PB16_O, SPORT2_CLK_I);
    SRU(DAI_PB17_O, SPORT1_DA_I);
    SRU(DAI_PB17_O, SPORT1_DB_I);
    // Route the BCLK and FS to the 1931 for slave mode
        SRU(SPORT1_CLK_O, DAI_PB07_I); // CLK -> 1931 ABCLK
        SRU(SPORT1_CLK_O, SPORT1_CLK_I); // required for master receive mode
    SRU(SPORT1_FS_O,  DAI_PB08_I); // FS  -> 1931 ALRCLK
        SRU(HIGH,PBEN07_I );
        SRU(HIGH,PBEN08_I );
    // Route the received data to the 1931
    SRU(HIGH, PBEN12_I);
    SRU(SPORT0_DA_O, DAI_PB12_I);    // DAIP12 (DSDATA1) to SPORT0 DA (TX)
    SRU(HIGH, PBEN11_I);
    SRU(SPORT0_DB_O, DAI_PB11_I);    // DAIP11 (DSDATA2) to SPORT0 DB (TX)
    SRU(HIGH, PBEN10_I);
    SRU(SPORT2_DA_O, DAI_PB10_I);    // DAIP10 (DSDATA3) to SPORT2 DA (TX)
    SRU(HIGH, PBEN09_I);
    SRU(SPORT2_DB_O, DAI_PB09_I);    // DAIP09 (DSDATA4) to SPORT2 DB (TX)
I have configured the SPORT as follows:
*pDIV1 = 0x001F001E;  //Receiver (SPORT1) at 12.288 MHz SCLK and 48 kHz sample rate
*pSPCTL1 = (OPMODE | MSTR | SLEN24 | SPEN_A | SCHEN_A | SDEN_A | SPEN_B | SCHEN_B | SDEN_B );
*pSPCTL0 = (SPTRAN | OPMODE | SLEN24 | SPEN_A | SCHEN_A | SDEN_A | SPEN_B | SCHEN_B | SDEN_B);
*pSPCTL2 = (SPTRAN | OPMODE | SLEN24 | SPEN_A | SCHEN_A | SDEN_A | SPEN_B | SCHEN_B | SDEN_B);
I have configured the 1931 to sync it's PLL to the ALRCLK, using the routing and SPORT setup above, the 1931 reports that it is able to lock.  I have also verified that the ABCLK and ALRCLK are present at the input to the 1931 chip.
With this setup, I am unable to hear any audio output from the 1939.  I have verified that the I2S lines comming into the ez-board look active and appear to have "normal" I2S traffic.
Any ideas?  Please let me know if there is other data that would help debug this issue?
Thanks in advance,
Kristopher
