SYSCON register (TS-201)
Question asked by Falcon on May 27, 2011
Latest reply on Aug 1, 2012 by jeyanthi.jegadeesan
Hello!
For some reason I can't change SYSCON register's value.
Here is a listing of a test code:
#include <defts201.h>
#include <sysreg.h>
int main( void )
__builtin_sysreg_write(__SYSCON,  SYSCON_HOST_WID64
                                                   | SYSCON_MP_WID64
                                                   | SYSCON_MEM_WID64
                                                   | SYSCON_MSH_PIPE2
                                                   | SYSCON_MSH_WT0
                                                   | SYSCON_MSH_IDLE
                                                   | SYSCON_MS0_WT3
                                                   | SYSCON_MS0_SLOW
                                                   | SYSCON_MS0_IDLE
                                                   | SYSCON_MS1_PIPE4); //=0x00389627
return 0;
The default value of this register is 0x00189067. I suppose this code to set a new value of 0x00389627 but it does not work. However, if I run with a breakpoint before "return 0" line, SYSCON register's value is changed sucessfully.
I have also tried to wait while the register's value is changed reading it in a loop but it never changes:
#include <sysreg.h>
int SYSCON_value;
int main( void )
                                                   | SYSCON_MP_WID64
                                                   | SYSCON_MEM_WID64
                                                   | SYSCON_MSH_PIPE2
                                                   | SYSCON_MSH_WT0
                                                   | SYSCON_MSH_IDLE
                                                   | SYSCON_MS0_WT3
                                                   | SYSCON_MS0_SLOW
                                                   | SYSCON_MS0_IDLE
SYSCON_value=__builtin_sysreg_read(__SYSCON);
while(SYSCON_value != 0x00389627)  {
return 0;
How to change value of this register without using breakpoint and why doesn't the first example work?
Thanks in advance.
