21375 EZ kit block based talkthru(C),FIR make a noise!
Question asked by Sunnyhgh on Oct 30, 2015
Hi:
  I'm  new for dsp.When  dsp perform fir process in excample " block based talkthru(C)"on the 21375 EZ  board,fir make a noise!
here is my code:
======SPORT0 interrupt ISR=============
// SPORT0 ADC DMA ISR
void TalkThroughISR(int sig_int) /* No argument is passed in this ISR */
  //Increment the block pointer
if(isProcessing)ProcessingTooLong();
    int_cntr++;
    int_cntr %= 3;
    blockReady = 1;
// DMA RX/TX buffer array samples
#define NUM_SAMPLES 384
// FIR TAPS
#define TAPS  83
#define DL  ((TAPS-1)/2)
#define N (NUM_SAMPLES/2+DL )
///////////////// FIR INPUT ARRAY//////////
           N0.  0          1           2          3     .....   191        192   193  194    233
adinputL[ DATA0, DATA1, DATA2, DATA3....,DATA191,  0,      0,      0....,0 ]
           N0.   0          1           2  .....    40(DL)    41         42       43           44           233
adinputR[ "invalid","invalid","invalid",....."invalid",DATA0, DATA1, DATA2, DATA3....,DATA191]
//FIR input L
float adinputL[N];
//FIR  output L
float adoutputL[N];
//FIR input R
float adinputR[N];
//FIR  output R
float adoutputR[N];
// FIR  states
float adstateL[TAPS+1];
float adstateR[TAPS+1];
// FIR  coeffs
float pm adcoeffs[TAPS]={
  -0.000403038195722,7.129271485026e-19,0.0004522593913585, 0.000761363609974,
  0.0007434622863051,0.0003094515963677,-0.0004442989071892,-0.001205202031486,
  -0.001534621077612,-0.001081448704452,0.0001678836573597, 0.001753810988894,
  0.002855118076214, 0.002664598363695,0.0008806529073619, -0.00195388951795,
  -0.004519403955275,-0.005269625469738,-0.003268848605737, 0.001101928378573,
  0.006016016776022, 0.008867545545789, 0.007545053831489, 0.001734700999099,
  -0.00647021389647, -0.01314835726836, -0.01426439863309,-0.007835843180117,
  0.004512188464698,  0.01755834878578,  0.02438698214213,  0.01959828726337,
  0.002481210944641, -0.02141101045025, -0.04132638701527, -0.04497487457391,
  -0.02353071250617,  0.02404398954612,  0.08930034378228,  0.1562204820565,
    0.2062782787256,  0.2248164317383,  0.2062782787256,  0.1562204820565,
    0.08930034378228,  0.02404398954612, -0.02353071250617, -0.04497487457391,
  -0.04132638701527, -0.02141101045025, 0.002481210944641,  0.01959828726337,
    0.02438698214213,  0.01755834878578, 0.004512188464698,-0.007835843180117,
  -0.01426439863309, -0.01314835726836, -0.00647021389647, 0.001734700999099,
  0.007545053831489, 0.008867545545789, 0.006016016776022, 0.001101928378573,
  -0.003268848605737,-0.005269625469738,-0.004519403955275, -0.00195388951795,
  0.0008806529073619, 0.002664598363695, 0.002855118076214, 0.001753810988894,
  0.0001678836573597,-0.001081448704452,-0.001534621077612,-0.001205202031486,
  -0.0004442989071892,0.0003094515963677,0.0007434622863051, 0.000761363609974,
  0.0004522593913585,7.129271485026e-19,-0.000403038195722
============Blocks FIR process ===================
/* Place the audio processing algorithM here. The input and output are given
  as unsigned integer pointers.*/
void processBlock( int *block_ptr)
  volatile int i;
    int temp_out;
    isProcessing = 1;
    /*Clear the Block Ready Semaphore*/
    blockReady = 0;
    for(i=0;i<NUM_SAMPLES/2;i++)
      *(adinputL+j)= __builtin_conv_RtoF((*(block_ptr+2*i)));
    *(adinputR+j)= __builtin_conv_RtoF((*(block_ptr+2*i+1)));
  // FIR process .
    fir (adinputL,adoutputL,adcoeffs,adstateL,N,TAPS);
    fir (adinputR,adoutputR,adcoeffs,adstateR,N,TAPS);
    for(i=0;i<NUM_SAMPLES;i+=2)
      (*(block_ptr+2*i ))=__builtin_conv_FtoR(*(adoutputL+DL+j));
      (*(block_ptr+2*i+1))=__builtin_conv_FtoR(*(adoutputR+DL+j));
    /*Set the Processing Active Semaphore before starting processing*/
    isProcessing=0;
NOISE:
And what I have to do with this problem?
