david.lewis@conexant.com
BT656 modes on ADV7611
Discussion created by david.lewis@conexant.com on May 10, 2011
Latest reply on Sep 13, 2011 by vito
Branched from an earlier discussion
Is there an easy way to output BT656 with embedded syncs from the ADV7611?  I tried using the register interface after power cycle with sw enable switch enabled.  It appears to be taking changes and I think it even changed to BT656, but is not receiving data properly.
I changed the OP_FORMAT_SEL field in the IO control to 10-bit SDR ITU-656 mode
