ADCLK854 Clock buffer phase noise
Question asked by bily on Oct 30, 2015
Latest reply on Nov 3, 2015 by pkern
Hi
I want to estimate 40MHz phase noise of ADCLK854 from datasheet fig.12.  I found a similar discussion in engineer zone.
https://ez.analog.com/message/28494#28494
My first question.
If input slew rate was not an issue at 40MHz and phase noise is -132dBc/Hz @ 1Khz offset. The buffer output phase noise will be ( -117dBc/Hz – 28db )= -145 dBc/Hz, So the output phase noise is better than input. Is that right?
2nd question,
Is it possible to calculate LVDS output phase noise when input signal is : 40MHz LVPECL phase noise = -142 dBc/Hz @ 1KHz offset ?
Thanks.
