FILTER IN C in ADuC7024-DATA FORMAT
Question asked by Abi on May 9, 2011
Latest reply on May 24, 2011 by MMA
Hello
I am using ADuC7024. I am trying to implement a FIR filter whose coefficients are generated  using MATLAB sptool. The coefficients are the following:
h[]= {-0.0111294364829681,     -0.0250411871348976,     0.00634770026237138,     0.0217101096024431,     -0.0373758385155041,     0.00697235792924841,     0.0637804820886267,     -0.105287994376181,     0.00693697340286084,     0.546129280297772,     0.546129280297772,     0.00693697340286084,     -0.105287994376181,     0.0637804820886267,     0.00697235792924841,     -0.0373758385155041,     0.0217101096024431,     0.00634770026237138,     -0.0250411871348976,     -0.0111294364829681     }        ; // filter coefficients
I am using float data type for the matrix "h".
In the filter implementation, I am multiplying the ADCDAT register with filter coefficients:
     ADCDATA[] * h []
(where  ADCDATA[] = (ADCDAT >>16))
In the above multiplication, h[] is float, so result is also float. Then I need to pass this result to DAC1DAT like this:
acc=acc+ h[]*ADCDATA[];
DAC1DAT= (acc << 16);
Like acc is float, then it is not possible to use the binary operand "<<"
Any idea of how to solve it?
One solution could be to convert h[] (coefficients of filter) into hexadecimal but is it possible ?, if yes then how ?
ADCDATA is of 2 Bytes so after conversion of h[], result should also be 2 bytes.
Thanks
