IIO Blocks GNU Radio
Question asked by fpgaNoob on Oct 26, 2015
Latest reply on Oct 30, 2015 by larsc
Branched to a new discussion
I'm using an FMCOMMS3 on ZedBoard with a blank Linaro Distro. I built GNURadio on this distribution following GNU Radio [Analog Devices Wiki] . When I load up the cyclic-sine.grc example the FMComms2 Sink and Source blocks were not found. I added the respective xmls to ~/.grc_gnuradio (found in the analog gnuradio git that I cloned) and restarted GNU Radio. The blocks are now present.
When compiling the program I get the following output:
Executing: "/home/linaro/gnuradio-examples/top_block.py"
Traceback (most recent call last):
File "/home/linaro/gnuradio/iio-examples/top_block.py", line 13, in <module>
     from gnuradio import iio
ImportError: cannot import name iio
>>>Done
Line 13 in top_block.py is:
I'm sure there is a simple solution to this but I haven't figured it out. Thanks.
edit: Inside of the build path (gnuradio/build) I ran,
     make -C gr-iio
     sudo make install
This did not affect the outcome.
