Strange behavior of SSPD of ADV7842
Question asked by JeffMcD on May 6, 2011
Latest reply on May 9, 2011 by JeffMcD
I am seeing two strange problems related to this.
Setup: ADV7842-ADV7511 Eval kit, with an external microcontroller connected to I2C lines, INT1 and ground.
1) If I get an STDI interrupt (which works great) and then I check to see if the SSPD data valid bit is set (and/or wait for it to be set) and use the remaining bits of that read to determined the trigger source, I get the wrong answer. I have a sync-on-green source connected but bits 1 and 0 indicate there is activity on VS and HS.  If I then read the value again using AVES, I get the correct answer.  It appears that the data valid bit is getting set too early.
2) If I enable SSPD data valid interrupts, it prevents other interrupts from working, including the manual interrupt. If I set IO reg 0x46 to 0x10 everything is fine. If I set it to 0x90 no interrupts work.
Any ideas?
Jeff
