ADRF6755 LOMON output
Question asked by sss on Oct 20, 2015
Latest reply on Oct 23, 2015 by sss
Hi,all
About the "controls the LO monitor outputs" and the "LO output circuits" at the ADRF6755,
in the datasheet 37 page @ ADRF6755,
" If not used, these outputs should be tied to REGOUT."
and 29 page,
"Register CR27, Bit 2. Controls the LO monitor outputs, LOMON and /LOMON.
The default is 0 when the monitor outputs are powered down. "
Q1
If it does not used LO monitor outputs, only setting the power down bit 0 is imperfect ?
and need to be tied to REGOUT ?
Monitor power down is open-collector outputs?
Q2
If controlled the LO monitor outputs on/off, it is necessary the all parts in the recommended circuits ?
In the datasheet 39 page @ ADRF6755, LOMON to +3N_INT, L1, L3/R60, R44.
Q3
LOMON single-end output is available?
Best Regards,
sss
