Frame Sync Edge Detection does not work on ADSP-21469
Question asked by kenfred on May 5, 2011
Latest reply on May 20, 2011 by kenfred
I recently discovered the following from the chip anomaly document:
http://www.analog.com/static/imported-files/ic_anom/ADSP-21467_21469_anomaly_rev.D.pdf
"15000007 - Frame Sync Edge Detection (FSED) feature in SPORT TDM mode does not work:
DESCRIPTION:
The newly defined Frame Sync Edge Detection (FSED) feature in SPORT TDM mode does not work. This feature was introduced to ensure
that when a SPORT is operating in TDM mode with external clock and frame sync, it waits for an active edge of the external frame sync
signal before initiating SPORT RX/TX transfers, regardless of whether it was enabled during the time of the frame sync signal being at an
active level.
WORKAROUND:
Do not set the FSED bit (bit 2 within the SPCTLNn register). This will ensure that the SPORT functions identically as on prior products."
I assume this means that TDM mode must operate in a level detection mode.  Does that mean I should monitor the external FS and only enable the SPORTs when the FS is logic low?
Thanks!
